Question about Westinghouse Leviton White Single Pole Wide View Motion Activated Light Control - R02-IPS02-1LW
I want to adjust the delay on my light switch
Adjust shutoff timer
Trying to set switch for 5 minutes , and i only get 30 seconds or 15 minutes
Which brand and model number specifically?
Leviton: 1-800-824-3005
Leviton Decora manual says:
"PR180 operates by detecting motion (such as body heat) within its field-of-view (area of coverage) and automatically switches lights ON. When motion is no longer detected, lights remain ON for a selected time and automatically switch OFF.
Adjustable light and time-delay controls are located on the front of the device."
The manual is not specific about set times.
In any case, the device has off-delay timing circuit, so once infrared heat is no longer sensed, the delay period begins, and once the delay period expires, the device is switched off.
Delay timing circuits are common for many home and industrial applications.
As a general rule, delay timers can be set for different time durations, however the Amazon page that sells PR180 product does not specify available time settings either.
Legrand RW3U occupancy sensor spec sheet says adjustable time delay 15 seconds 5 minutes, 15 minutes and 30 minutes
http://www.amazon.com/Legrand-RW3U603I-Occupancy-Vacancy-Decorator/dp/B005FMLL5G
Delay switches
Here is manual delay-time switch Tork SS20 SS13 where you can 'fine-tune' the delay circuit, but my experience is that exact 5 minutes is not easily set:
http://waterheatertimer.org/images/Paragon-ET-series-243.jpg
GE 15318 switch offers 5 minute, but there is no guarantee that you can get 5 minutes exactly:
http://waterheatertimer.org/images/GE-15318-countdown-timer.jpg
My conclusion is that there are very limited delay-time choices with this model number, or device is defective and suggest to call Leviton.
Sep 23, 2012 | Leviton R01-PR180-1LI Decora 180 Degree...
How to install timer delay
It depends on exactly which timer you have, and what you are controlling and how you are activating timer, and if you are using OFF-delay or ON-delay.
Something has to switch the timer ON, like a push button, and then the delay period begins.
The wiring diagram appears on side of timer.
Keep in mind that most delay timers are rated for low amperage loads, and can be used to control a contactor that controls heavy-amp motor load.
Copy following links to get started, and then repost with exact specifications of project: model number of timer, voltage, what you are controlling etc.
http://waterheatertimer.org/How-to-wire-pin-timers.html
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 10, 2012 | Hardware & Accessories
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
To palaboy: when you talk about a switch on the left most terminals, you mean with this switch im enable the timer???
Question is not clear.
You posted about Dayton on-delay timer?
This timer has two contacts, and wires similar to a light switch.
Connect 120V power to terminal 1
Connect wire going to load to terminal 3
Maximum Load is 1 amp so this timer should be wire to a contactor/relay and not directly to Load.
If you have Dayton off-delay timer, open following link for wiring diagram, and to see examples of contactors:
If you have a different timer, then add a comment with clear description of timer or in-focus photo of timer posted on Flickr
Jul 11, 2011 | Amperite Dayton Solid State Timer On Delay...
Is their a way to adjust the delay time on a 390-6107xx-eg1d motion sensor light? If I stand still it cuts out in 3 seconds
There is a switch on the front that allows for different times before shutdown. Also there is a smaller dial beneath the panel that lets you adjust the sensitivity. Try adjusting it to be more sensitive ( + ) so that you are seen and then the timer should kick in.
Feb 28, 2011 | Cooper Wiring Devices Motion Sensing...
I am in need of some advise. I have a pellet stove and need to replace an obselete part, I am wondering what would be the best delay relay timer to use, it will operate an 6rpm/150lb torque auger that goes...
1) Pex supply sell the E502 OFF delay Paragon product: Timing cycle begins when switch is activated, and shuts down at end of timing cycle. 5 seconds to 3 hours
http://www.pexsupply.com/Paragon-E502-Electronic-Off-Delay-Timer-5-sec-to-3-Hrs
http://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hb
See manuals for Paragon product:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#percentage
2) Tork ACT120 cycle timer (minimum ON is 30 seconds)
http://www.grainger.com/Grainger/TORK-Adjustable-Cycle-Timer-4JNH8?Pid=search
http://www.nsi-sales.com/act_series.htm
See ACT manuals:
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle
3) Intermatic CT1000 cycle timer: cycle durations of 30 seconds to 30 minutes, with on-off durations from 1 minute to 29 minutes.
Click model number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/percentage%20cycle%20timers.aspx
Drillspot sells indoor/outdoor 120V or 240V CT1000
http://www.drillspot.com/products/1325934/Cycle_Timer_CT1000_Cycle_Timer?s=1
4) Do a google search for 'electronic cycle timer' or 'percentage timer'
5) Timers listed above can be wired to a contactor (or relay) that turns on auger, if that's what project calls for.
Dayton off-delay timers require push-button operation
Feb 03, 2011 | Amperite Dayton Solid State Timer On Delay...
My interior lights won't go off
Fault in one of the door switches or if thre is timer delay for the lights to dim off then it is short in the control board of the delay switch.
First make sure all the four switches work before you can confirm on the delay timer.
Sep 18, 2010 | 2002 Ford Taurus
Delay switch for lights and where is it 2001 dodge dakota club ca
The delay for the headlights is the up/down adjustment wheel
to the right of the headlight switch. apollo466
Jun 03, 2009 | 2001 Dodge Dakota
Delay Timer for self portrait
you can choose 2 or 10 seconds delay
May 15, 2009 | Canon PowerShot A75 Digital Camera
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Westinghouse Leviton White Single Pole Wide View Motion Activated Light Control - R02-IPS02-1LW Logo
Top Westinghouse Home Security Experts
Lawrence Oravetz
Are you a Westinghouse Home Security Expert? Answer questions, earn points and help others
