Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Main burner will not light. pilot has now gone out
Main burner would not stay lit, then would not light at all. Reading at the pilot generator was erratic, then dropped to less than 100mv. At first I thought defective pilot generator but now think maybe a clogged or defective pilot. My question is, how do I get the pilot generator/pilot out to clean or replace? I have the manual but it does not help.
  • 23 Answers
Shut off the gas at the gas **** and gas valve. the pilot tube is held in place by a 7/16 compression nut. remove it then remove the 2 screws for the thermopile "generator". follow the pilot tube and the pilot assembly should be held in by one or two screws. usually you don't have to remove the main burners. hopefully this helps
Posted on Jun 15, 2009
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
How do I clean or replace the pilot generator on a Jandy Lite 2 pool heater? The pilot will stay lit but the main burners will not come on. Jumpering the gas valve will ignite the main burners and the
if the pilot stays lit and main burners wont fire you don't need to replace the pilot generator! you have an open safety, poor electrical connection or a problem within the tstat controls
Aug 19, 2014 | Pool & Spa
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
I HAVE A DESA LP VENTLESS FIREPLACE AND THE PILOT WILL NOT STAY LIT
the heater makes use of a millivolt generator which generates a small dc voltage (500-750mv) that is applied to the pilot valve of your main gas valve. when you light your pilot, the flame bathes the generator with a flame. after a delay you release the pilot button. if the generator is working, the pilot valve will stay lit. if the generator is not working the flame will go out as soon as you release the pilot button. change the generator.
Oct 13, 2009 | Desa International Heating & Cooling
Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Oct 07, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Main burner too hot & 2nd burner pilot won't
Set t/stat to 250 degrees. If it does not shut off after about 5 minutes, replace t/stat.If shuts off, must be calibrated Pilot may be dirty, flame weak. If flame strong, replace thermopile(pilot generator). If weak, must remove and clean pilot orifice inside pilot.
Aug 29, 2009 | Keating Kitchen Appliances - Others
Main burner not lighting
Could be bad coupler or pilot valve is not staying up due to bad spring. If the light does stay lit at all, then the problem is with the fuel.
You can get the entire pilot assembly for $70 at poolcenter.com
Jul 05, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
Pilot lights, main burner will not. Replaced gas valve, no change
I had a problem with the same stove,same model no. etc. Needed new valve. Will replace tomorrow, I will let you know how I make out.
Apr 06, 2009 | Vermont Casting VCS4017 (NG)
Heating & Cooling Logo
309 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
