Question about GE JKP85 Electric Double Oven
Remove microwave door
Need to remove door from hinges
HOW DO I REMOVE THE OVEN DOOR & HINGES FROM ST GEORGE UEOLAS ELECTRIC OVEN PLEASE
Most oven doors can be removed by opening door and pulling straight out. The hinges are attached to the oven frame not to the door. Some oven doors have screws that are attached to the hinges at the bottom of the door on the inside that need to be removed, then pull straight out.
May 16, 2016 | Ovens
How to remove door hinge technica oven t948 please
This should be fairly easy. It does depend what model of hinge you have. On the bottom of the hinge there is an arm with a saddle lock pin - this pulls up to give space to lift the fitting off the oven frame - lift these on both hinges. On the face of the hinge where it sits on the door there should be a round screw - with the door fully open using a flat blade screwdriver turn this 45 degrees clockwise - this locks the top bar that goes to the frame of the oven.
Hold the door and with a bit of wiggling the whole door should lift off. The hinges are now easily removed by disassembling the door. Replace both hinges with new and reverse the process to replace. You do not need to remove or disassemble any part of the actual oven.
May 30, 2014 | Ovens
Oven door won't quite close tightly. I can push it about another 1/4 inch to close it completely.
You need to replace the hinges in the door. Go online to a spares website and enter make and model and order new hinges. You can replace them by unhooking the door, just takes a little effort, you might need to flick back latch on hinge and lift out. Remove inner door panel, usually 4 screws and remove. then change hinges. The 2 big pieces are the hinges.
  • images?q=tbn:and9gcsg1plmaxnucdapg-xpimmjauz_p4kgblmyf6iotcmgyh-hv4v3
Mar 09, 2011 | Ovens
I need to replace the light bulb in my whirlpool self-cleaning oven but I can not remove the glass cover. How do I remove it?
hello,
Here is a solution to go about the glass bellow
Removing your microwave door allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
  • Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  • 2 Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door. Work around the edge of the glass until the cover slips free.
  • 3 Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
  • hope this solution help?
    Thanks for visiting fixya.
    Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
    Ovens come in many varieties including freestanding units and stacked models that are inserted into a wall. Kitchen oven units that get a lot of use or are getting old may have problems develop, such as a loose or squeaky door which may require replacing the hinges. You can replace the hinges on the door to your oven by first removing the door from the rest of the oven.
    jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions Things You'll Need:
    • Screwdriver
    1. Step 1 Open the oven door and examine the hinges to see how the they are secured to the door. Some oven doors slide into the hinge assembly or have a locking mechanism that secures the door to a latch on the main unit.
    2. Step 2 Remove the door from the oven by disengaging the locking mechanism and then pull the oven door out. You may need to release a catch on the door or remove a pin from a hole in the hinge.
    3. Step 3 Place the door on a flat surface such as a table or the floor.
    4. Step 4 Remove the screws that hold the sections of the door together to access the hinges.
    5. Step 5 Remove the hinges from the door. The hinges may be attached to the door with screws or they may be held in place when the door sections are tightened or secured.
    6. Step 6 Insert the new hinges into the door and secure them with the screwdriver or place the section of door back on. Tighten all of the screws securing the sections together.
    7. Step 7 Place the oven door back into place by sliding it on the same way that it came off.
    Regards
    Iversh
    Jul 24, 2010 | Ovens
    Removing the door from a thermador oven CT130
    Usually you will find a hole in each hinge to hold the hinge open when removing the door.
    It is impossible to fight the door hinge springs and remove or install the door.
    One opens the door and puts a nail through the hole to keep the hinge open for each hinge.
    Feb 20, 2010 | Thermador Ovens
    Doors don't shut all the way and light stays on
    It sounds like your door hinges are worn, usually on older ovens due to weight of door. Most oven doors can be removed by simply raising the tabs/ fitting small screwdriver on both hinges(refer to user manual) etc. Once door is removed you can place a medium size screwdriver or similar in the hinge slot, pushing the hinge plate on the bottom in an outward direction, thereby bending this plate(very slightly) forward. This will make the door close fully, activating the door switch, and turning off the oven light. This is only a short term solution, as this hot air escaping can lead to further problems. Hinge pair will need replacing. Door hinges are spring loaded ALWAYS KEEP FINGERS AND HANDS CLEAR OF LOADED HINGES.
    Sep 18, 2009 | Jenn-Air JJW8230D Electric Double Oven
    Thermador oven (c301u) door hinges weak, how to install new hinge
    This is a relatively easy fix however you will need to remove the door and it is heavy!
    Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
    Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
    Good luck!!
    The hinges are commercially avaialble from Applianceparts.com
    Jan 18, 2009 | Thermador C301U Electric Single Oven
    Jenn -air oven w30400p
    Do you mean the service engineer replaced the hinges?
    If so call him again and tell him he didn't fix it. The service engineer should come again and fix it for free if there's any justice in this world.
    Nov 08, 2007 | Jenn-Air W30400P Stainless Steel Electric...
    GE JKP85 Electric Double Oven Logo
    18 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
