Question about Bosch Nexxt 500 Plus Dryer
Bosch Nexxt 800 series dryer E01 error
Bosch Nexxt 800 series dryer does not run more than 15 - 20 minutes without the sensor alarm going off and the dryer showing and E01 error message. We continually clean out the lint filter but nothing helps.
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Posted on Mar 11, 2012
  • 3 Answers
If you are using dryer sheets...stop. They clog your linter filter. Use windex to clean the filter and a soft bristle brush....also check to ensure your dryer vent is clear using a shop vac to clean or a vent brush.
Posted on Dec 01, 2009
  • 23 Answers
There is a sensor towards the bottom of the place you have the lint screen. That might be bad or covered. What I have done in the past was take an air compressor with a blow tip and blow down where the lint screen goes to clean it out. After spraying for a while, turn the dryer on a bit and it will blow a bunch of stuff out the vent tube.
Posted on Aug 15, 2009
Bosch Nexxt Washer Error Code E01
means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
Bosch Front Load Washer Error E01
Dec 01, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch nexxt 800 series wtmc8520uc not working
How do you get to the motor mount? Where is it located?
Jan 22, 2012 | Bosch Nexxt WTMC8320US Electric Dryer
Bosch Nexxt wtmc6500uc dryer. We receive an e01 error with every load and now cannot run the dryer at all. The vent is less than 5' with one bend, we clean the filter with every load, we've replaced the...
This was a previous post, but it may work for you.
A friend of ours has a bosch gas dryer and she had the same problem. She called the Bosch repairman and he sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try.
Feb 12, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
E:01
Check for the following if you get "E01" error message
1. Check for the vent hose whether it is clean which is less than two feet (to outside).
2. Check for the temperature sensor probes one in back at heating element and one in front by the lint filter for the temperature rises resistance increases on both of them and vice verse.
3. Check whether the unit has been grounded.
4. Check for the element that turns off and on during drying process.
5. When first starting and dryer is cool it will dry one load of clothes, it also seems to work for at least the first part of the cycle, until clothes began to get dry then it over heats. display shows E01 and will not run until it has set for about an hour.
Thank you!
Jun 21, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Error code E:01
Hi and welcome to Fixya, The E01 error for your bosch indicates a door lock problem has been detected at the control board. Insure the door is closed tight, turn your breaker off or unplug the washer for a couple of minutes and retry. Let me know what happens, ultimately it may be a faulty lock assembly, a loose wire harness etc. but we'll cross that bridge when we get there...if necessary. I'll watch for you to respond with the result's. Good luck. Macmarkus :)
Jun 07, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
E 01 display and beeping
Hi
Check for the following if you get "E01" error message 1. Check for the vent hose whether it is clean which is less than two feet (to outside). 2. Check for the temperature sensor probes one in back at heating element and one in front by the lint filter for the temperatur rises resistance increases on both of them and visa versa. 3. Check whether the unit has been grounded. 4. Check for the element that turns off and on during drying process. 5. When first starting and dryer is cool it will dry one load of clothes, it also seems to work for at least the first part of the cycle, until clothes began to get dry then it over heats. display shows E01 and will not run until it has set for about an hour.
Thank you!
May 09, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Our dryer reads E01. I can't locate our manual so what does that mean? Thanks
E01 - lint filter dirty, exhaust air duct is blocked or too long, fault in program sequence or malfunction, the room/cabient is not adequately ventilated.
Feb 13, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
Oct 28, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 Plus Dryer Logo
2,038 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
