Question about Jet 7 Portable Power Chair
After charging my batt. my controller wont light up or do nothing
After charging batt. controller wont come on or do nothing
    Master:
  • Jet Master
  • 401 Answers
Check the cables, and battery wiring
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Posted on Oct 10, 2017
My battery died and put the charger on it but now the radio wont turn on and the lights and controls for the ac don't work?
Some cars..the module is affectd if batt ran low..below 12.6v they can be ruind. Test batt for holdn a charge. Same w alternator. Also the main cable from batt to alt cud b worn causing low flow
Jun 30, 2015 | 1994 Oldsmobile 88
Battery light on, got new alt., starter tries to engage, but doesnt
Did you have the charging system diagnosed or did you just guess at it being the alternator . The charging system is computer controlled . The starter isn't working because low power , battery dead . Is there B+ voltage at the wire on the back of the alternator .B+ voltage at pin 3 at the connector pluged into the alternator .
Charge the battery use a volt meter an test for B+ voltage at the places i mention . No check engine light ? DTC'S - diagnostic trouble codes stored .
Ford Smart Charge System Alternator Not Charging
Ford PCM controlled alternator testing
Aug 26, 2017 | 2004 Ford Focus
I have a 2000 cougar, batt light wont go off, stalls out like alternator isnt working. Wont charge batt at all! Could using a dide mounted batt instead of top mounted batt be a priblem?
your charging system should show 14+v at the battery when running-it doesn't matter what the battery is if alternator is not putting out -cheers Denny
Dec 04, 2013 | Cars & Trucks
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
My 95 surburban wont crank changed the stater got a new batt and new batt post still wont crank
Obtain a 12 volt test light, ground the clip on the negative battery post, and check for light at the large terminal on the starter solenoid. If lit, have someone try the key--if the light goes out, place the light on the battery positive post and try the starter again. If it goes out again, either the battery needs to be charged, or it is defective. If the light stays lit in the first test, then place the light on the starter motor terminal and retry the key (do you hear a fairly loud click?). If nothing but the click, replace the solenoid itself. If no click at all, test the small terminal on the solenoid and try the key. If you get light, replace the solenoid. If no light, check for blown fuses. If ok, then suspect a bad ignition switch. Hope some of this helps!
Mar 31, 2010 | Chevrolet Suburban 1500 Cars & Trucks
2000 camaro, i turn key and car wont start , nothing, the lights go on and everything is charged but it wont crank or anything
how old is the battery most cases the batt is dead even thou lights and all come on but just dose not have the juice to start it,
or your ternimals plus and minus are loose tighten them up till you can't move them by hand and give that ago if not working try new batt
Oct 31, 2009 | 2000 Chevrolet Camaro
97 civic new battery wont hold a charge alternator is fine....any ideas... thnks gf
remove pos batt cable from batt install test light in line. One end on batt other end batt cable. See if test light burn.s bright with car turnd off' Unplug fuses one at atime until you find on that makes the light go dimmer. then look in maual to see whats on that ckt'
Jun 24, 2009 | 1997 Honda Civic
Wii remote is not responding and every time i press a button the lights flash, after the battery was fully charged. I put regular bateries and nothing, either.
you might have to re sync the remote to the consol again open the front cover with the wii on press the red sync button then press the red button inside the batt compartment on the remote you will have to have reg batts in the remote to do this then put the rechagable pack back in this might help ive had to do this a couple times
Jun 20, 2009 | Eforcity Charging Station for Nintendo...
Jet 7 Portable Power Chair  Logo
148 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
