Question about Tatung Computers & Internet
Replace adb tatung 2120199
How do i replace?
My alcatel is asking for an adb sideload. How do I do this?
Probably every Android power-user at least once in his life used ADB - Android Debug Bridge. It is a versatile command line tool that lets you communicate with an emulator instance or connected Android-powered device. Using ADB shell commands gives you additional control over your device and sometimes it can save your device from being bricked (example: How to: copy ROM zip file to the freshly wiped device). You can find some more basic information about ADB here.
How to: copy ROM zip file to the freshly wiped device. The main difference is that ADB sideload works only with recoveries based on Jelly Bean source or newer. I believe that ADB sideload was created to simplify the process of flashing/restoring Android update.zip packages.
Keep in mind that while using ADB sideload, the regular ADB shell won't work. To be able to use SIDELOAD mode make sure you're running latest ADB drivers from the Android SDK (Platform-tools). Here are the simple steps you need to follow to flash update.zip package using adb sideload mode (based on stock Android recovery):
  1. Place the ZIP package you want to install in the same location where you keep ADB drivers - adb.exe, AdbWinApi.dll and AdbWinUsbApi.dll (usually it's SDK\platform-tools)
  2. Make sure you have USB debugging enabled in Settings > Development on your device
  3. Make sure your phone drivers are installed on the PC you're going to use
  4. Boot your device in recovery mode (Android logo with a exclamation mark) and connect your device to PC
  5. Hold down "power" button first, followed quickly by "volume up" button. You should now see the recovery menu
  6. Use the volume up/down keys to select "apply update from ADB," then press power to select it
  7. Open a command prompt on the PC (cmd.exe), type and confirm with ENTER:
  8. cd /d <adb.exe location> (for example: cd /d c:\SDK\platform-tools) or you can open your SDK/platform-tools folder, then press SHIFT button and the right-click mouse button and choose "Open command prompt here"
  9. adb sideload <filename>.zip (for example: adb sideload update.zip)
  10. The zip package will begin installing. When it's done, select "reboot system now."
How is that different from the alternative method? You don't have to manually create the proper folders structure, push the file and later install if from inside the recovery menu. The result is basically the same, because ADB sideload is also transferring the zip file into the device internal memory and later it automatically begins the installation procedure. However, it works only with recoveries based on Android Jelly Bean source.
May 16, 2015 | Alcatel Cell Phones
Tatung rice cooker #TAC 10 CUP. The cook/warm switch button constantly pop up during cooking time. Do anybody knew how to fix the problem?
SWTCH IS DIFFECTIVE AND ONLY EXPERIANCED TECHNITIANS CAN REPLACE IT.REPLACING THE SWICH WILL SOLVE YUR PROBLEM.IF NOT CHECK THERMAL SWITCH.
Nov 04, 2013 | Tatung Kitchen Appliances - Others
Sanei a76 tablet more pattern lock attempt. how to remove unlock my tab please help.
Here is the trick to unlock your Sanei 76 tablet pattern and Gmail :
1) Download Android SDK and install Drivers
2) Open ADB in Command Promt (cmd)
eg : my adb file is stored in this directory
c:\android sdk\sdk\platform-tools\
so to open adb inside this director i use the command
cd c:\android sdk\sdk\platform-tools\
7ac56502-9b5e-40ad-a42e-02deb0a64701.png 071aa9ed-d87b-43b7-aaf9-a53a9c9c27c3.png
3)type the command adb devices to check wether your device/tablet is connected to your PC
(if your device is connected you will get some thing like this : 727ab014-596a-4066-9df4-dbb8eb522e6a.png
4) Then type the command adb shell.
you will get some like shown below
5)if you got symbol rounded in the above screen shot download this file and run it.(if your device is not rooted)
http://downloads.ziddu.com/download/23715300/root.rar.html
6)The type su in adb shell
you will get super user privilages
7)Then type the command below
wipe data
8)the type command reboot
9)Now you are done you are successfully removed your Gmail and Pattern lock.
Oct 06, 2013 | Tablets & eReaders
I have just purchased a pandigital novel ereader and my computer can not find a driver for a S3C6410 Android ADB. There was no disc with any drivers in the box. Where can I get this driver to make the...
Hi enpugh,
Here is an article titled:
How to install and set up the Android ADB drivers.http://www.softsailor.com/how-to/20430-how-to-install-and-set-up-the-android-adb-drivers.html
but I'm not sure if this is what your looking for.
Here is an Android Forum that might help you:
http://androidforums.com/captivate-support-troubleshooting/186357-cant-install-adb-drivers.htmlhttp://androidforums.com/captivate-support-troubleshooting/186357-cant-install-adb-drivers.html
and an article titled: How to Install Apps using ADB
http://androidcommunity.com/forums/f4/how-to-install-apps-using-adb-4482/
Hope this helps.
Dec 26, 2010 | Computers & Internet
My Tatung LD23HL Flat screen will not turn on. Is there a reset? When plugged in the power light blinks Orange.
check the monitor to computer cord, sounds like it might be loose or disconnected. swap another monitor in and go to display properties to see if the tatung is a 2nd monitor. using the replacement monitor redownload the drivers and reinstall. turn off and hook the tatung back and it should recognize it
Oct 09, 2010 | Tatung LD23HL Monitor
Need to replace power supply for Tatung V32GCGI
Just time and patience. If possible use a pencil iron. A gun is too much heat for the board. If you have the exact replacement be aware how the old one comes out.
Feb 16, 2009 | Tatung V30DMTT 29.6 in. LCD Television
Tatung TV Video Combi won't play
You need to replace the motor belt charge maybe is on bad conditions.
Jul 24, 2008 | Televison & Video
Tatung lcd 42
This is a known Tatung Issue. If you still have your warranty, deliver it to the repair shop. They will fix it in a day.. That's what I did
Mar 20, 2008 | Tatung P42BSKT 42 in. HD-Ready Plasma...
Computers & Internet Logo
23 people viewed this question
Top Tatung Computers & Internet Experts
Tony
kj henriksen
kj henriksen
Are you a Tatung Computer and Internet Expert? Answer questions, earn points and help others
