Question about Kenwood DNX570HD
Poor am radio reception
Very poor am radio reception
Poor reception
There are many causes for poor reception on a cb radio one cause may be poor or poorly assembled antenna, a good antenna should be of highest gain and put up as high as possible ,An omnidirectional antenna or Ground plane will hear moderately well
in all directions but a directional antenna or Yagi will hear great only in the direction it is turned you will certainly have to decide what you or your homeowners association will allow.
Also and finally The sun is a major factor in communications Propagation sometimes no mater what your setup the reception is terrible.
Feb 24, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Poor radio reception
check your antenna wire to see if it came unplugged from back of radio
May 18, 2013 | 2002 Ford Crown Victoria
Poor radio reception and Setina push bar installation question
for the poor reception have you plugged in the antenna wire into the radio
Poor reception when trying to get MW
Poor reception or with heavy noise aas the interference is very high on the MW. If there is no signal strength then the fault can be due to faulty RF in the radio, poor MW oscillator settings or a faulty IF settings.
Also a faulty antennae can cause poor reception and pick of stray signals.
Check for other interferances from household applicances.
Nov 07, 2011 | Car Audio & Video
Poor radio reception 04 Jetta
It may be more of a design flaw oppose to a actual problem. However, you can purchase signal booster that simply plug between the radio and the cars antenna.
Apr 23, 2010 | 2004 Volkswagen Jetta
FM reception for Sony ICF-CD513?
The electrical cord acts as an antennae for this radio. Uncoiling the cord will give the best reception for FM. Rotating the radio (and built in ferrite bar antennae) will give the best reception for AM listening.
Jan 31, 2010 | Sony ICF-CD513 Clock Radio
Chk. for a poor connection wear entenna plugs into radio, it could have corrosion or it could just be loose.
Sep 06, 2009 | 2003 Volkswagen Jetta TDI
could be or the station you have on.in between towers you will get static.
Jul 15, 2009 | 2007 Mini Cooper S Convertible
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
Kenwood DNX570HD Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
