Question about Frigidaire Professional Series PHS68EJSB Stainless Steel Side by Side Refrigerator
Frigidaire freezer leaking
Leaking
Code H1 on my frigidaire ffhs2622mwla refrigerator
HI is an error for freezer temperature detected as too warm... Look for frost on the back wall of freezer (defrost failure), or a failed evaporator fan (you should hear it running in the freezer compartment), if the food in the freezer is beginning to thaw, check the compressor to see if it is running. If the compressor is running, but the freezer isn't cold enough, and the evap fan is good with no frost build-up, you may have a sealed system leak (refrigerant charge is low). Frigidaires really suck in recent years and have lots of leak issues...
Jun 20, 2016 | Frigidaire Refrigerators
Frigidaire upright freezer is leaking water from the door What is the problem?
Hello friend, I appreciate your post!
From the information you have provided your Frigidaire freezer is leaking water from the door. It could be a build-up of condensation on the interior of your freezer or the drain line. I would recommend checking the gasket to make sure that there is no visible damage you should also check the gasket to make sure it is sealing properly. You can use a dollar bill to check the gasket. Place it between the freezer and door, if it comes out with little resistance then the gasket is bad.
You can also perform a manual defrost on the freezer by disconnecting power from it for at least four to six hours. I hope this is helpful information. -Matt
Mar 16, 2015 | Frigidaire Upright Freezer
Why is my fridgidaire freezer leaking water and the defroster not working?
Hi Friend, this is Z. Thank you for your post!
I understand your Frigidaire freezer is leaking and not defrosting; however is water leaking from behind, front or underneath? Also, did you notice any error codes, noises, or other strange functions prior to this issue? With this information I can assist you better in pinpointing the problem.
Jul 07, 2014 | Frigidaire Freezers
Can you recharge the freeon in a frigidaire upright freezer?It's not as cold as it should be!
I the freon has leaked out, this means there is a leak in your sealed system. Unless you can find the freon leak, charging the system will do no good. It will leak out again. There are many things to cause a freezer to not freeze. Is this a "Frostless" Freezer or a "Manual Defrost"?
Mar 30, 2012 | Freezers
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Freezer leaking
your drain is probably plugged with something take tha back off of the freezer and find the drain .... let me know what you find out...
Jun 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Deluxe Chest Freezer is constantly
Two things to check without knowing the model number.
It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
May 02, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire Professional Series PHS68EJSB Stainless Steel Side by Side Refrigerator Logo
21 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
