Question about Staples SPLXC200D Shredder
Need a part for a shredder
Need the plastic safety switch actuator that screws onto the bin.
2 Suggested Answers
luigihinston
  • 29 Answers
SOURCE: Need more help. Staples Shredder Model spl-1050lbrx still will not run in forward. With sensors blocked/bypassed the cutters will only step by tapping on the basket micro switch safety.
Do you know the story of Kakima and Lil J? Many years ago, a great battle occurred. Kakima struketh with great force and angst, but i passed him, and prevailed. With the greatest achievement on the website, i ran. but kakima chased me, and called the admins! How dare he? What has he doneth to the lil J? He got me banned, and i retrieved balance. I never came back until today. Im finally back to the city of england.
Posted on Jun 28, 2017
Testimonial: "Is this Spam?"
When bin was full, I emptied it only to find that my shredded no longer worked on auto, forward or reverse
Dear Sir,
Maybe, just maybe, I have an answer for you.
Somewhere on the part of your shredder that touches the bin, there is a tiny switch that touches the bin, and it is a safety switch that causes the shredder to stop working if the bin is removed.
In the shredder I have, and have had, the switch is usually plastic, and is the same color as the plastic body of the shredder.
Proper positioning of the bin to the "bottom" of the shredder is critical to it's working, as the bin presses on the switch to "close" it.
God bless your efforts.
May 09, 2016 | Techko SH1524CP Shredder
Where can I get the 8.14 gal. waste bin for an unidentified office shredder?
Trash Cans & Recycling Bins ' StaplesĀ®
www.staples.com/Trash-Cans-Recycling-Bins/cat_CL141928
Staples Inc.Use trash cans and recycling bins to keep plastic drink bottles, loose papers, and snack wrappers .... simplehuman® Slim Step Trash Can, Plastic, 10.5 gal.
13 Gallon Trash Cans : Trash Cans & Recycle Bins - Walmart
www.walmart.com > ... > Trash Cans & Recycle Bins
Walmart
Jan 01, 2016 | Office Equipment & Supplies
Shredder won't turn on when plugged up
Shredders have a safety switch that won't allow it to run if it is off of the bin. Sometimes if the shredded is on the bin backwards it won't run because the plastic piece on the bin that presses the switch is only on one side of the bin. Sometimes if the switch goes bad, the shredder won't run.
Jun 21, 2014 | Techko Identity Guard 6-Sheet Strip Cut...
Shredder won't shred does it need a security card?
I believe that it could be one of two problems. First of all, and the painfully obvious one, do you have the red power switch in the on position. Try moving it to different settings to see if it does work at all. If it does, put the switch back in the center position and try shredding again. If it doesn't work, then you may have a faulty shredder. (This and the following are believing that you have a new shredder and you are trying to get it to work for the first time.) Second, if you lift the unit off the paper bin and look on the bin, you will see a slight protrusion, like a "tab." When you place the unit onto the bin, this tab must be aligned with a slot on the shredder unit; the slot will have a small strip of silver metal inside, it is part of the safety mechanism. If you are using a trash bag - to make for easier shredded paper disposal - you might have to use a bit of pressure to make sure the tab makes contact with the little piece of metal. You also may have to turn the shredder unit around 180 degrees and re-seat the unit.
If it still doesn't work, call the service/warranty/support department and find out what you need to do next.
Mar 05, 2014 | Staples ID Armor IDX50B Shredder
Shredder does not run in auto or reverse
Make sure the shredder is in the plastic bin that was delivered with the unit and is seated in the proper direction. The clear plastic on the bin should be considered the front on the bin and the power switch on the top would be considered the rear.
Jan 01, 2014 | Aurora Electronics AS890C Shredder
The basket full light will not go out
YOU WILL HAVE TO HAVE SENSORS REPLACED
Sep 15, 2009 | Fellowes DM15C Shredder
What is the interlock for a staples shredder
if you look at the underside of the shredder, you will likely find a pressure switch that is actuated when it sits on the stock bin, either modify it to touch when on the new bin or secure it so it is depressed all the time. This should allow it to operate on the replacement bin.
Hope this is of some help.
Ed
Apr 20, 2009 | Office Equipment & Supplies
Broke the contact on the bin
There are two ways around this:
One way is to take the broken contact from the bin and tape it into the shredder so that it keeps the switch depressed.
Another way (what I did when I broke mine) is to turn the shredder motor upside-down, take the lid off (7 phillips-head screws), cut the 2 wires that go to the switch that gets pressed by the contact and twist them together (with a wire nut, or crimp it if you have a crimper). No more switch needed, and no need to purchase another bin.
Hope this helps,
-Wes
Feb 27, 2009 | Office Depot Ativa DQ60M Shredder
PS-70 Shredder problem
Make sure that the shredder is locked down in its case by pushing down on all 4 corners.
Since the basket slides forward to empty it, I would think the safety switch is located in the front but not positive since I don't have a unit right in front of me.
Check to see if you see a slot in the top part of the shredder unit. Usually the basket has a piece of plastic that will line up with the slot when the basket is in place (Safety switch) so that the top part of the shredder knows that the basket is in place.
Look around with a flashlight, If you are going to feel around with your hand, PLEASE MAKE SURE YOU UNPLUG the shredder just to be safe.
Hope this helps.
Good luck.
Mac =)
Feb 10, 2008 | Fellowes PS-70 Shredder
Red light on will not run in forward
Check to make sure the shredder is sitting on the paper bin properly. Most shredders have a sensor switch that disables the unit if it's not properly seated on the paper bin.
Jan 21, 2008 | Office Equipment & Supplies
Staples SPLXC200D Shredder Logo
43 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
