Question about Alcatel Radio Communications
W995 headset What is the pass word foralcate w995
In need of PUK code for soni W995 thanks
The PIN and PUK are features of the SIM card, so the best port of call is the service provider of said SIM.
Make sure you've not tried to guess or enter random numbers, as doing this ten times will render either the SIM or (worse) the device unusable.
Dec 21, 2014 | Sony Ericsson W995 Black Walkman Unlocked...
PS3 Bluetooth® Headset Wireless Headset: lost my pass key...
First try '0000' (four zeros). If it doesn't work, switch to '1234'. It it keeps failing, try '8888'.
Hope one of these codes might suit your case.
Cheers! Carlos
May 17, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Sony ericsson bluetooth headset tryin yo connect
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Nov 18, 2009 | Sony Ericsson Mobile Bluetooth Car Kit...
I recieved a repacement phone and I don't know what my pass key is. What is a pass key?
The pass key is a number the bluetooth headset uses so it can connect to the cell phone. The pass key for the headset should be 0000...Hope that helps.
Nov 07, 2009 | Motorola Mobility H700 Wireless Headset
Pass key
Pass keys for bluetooth pairings are usually 0000 unless the item is user configurable and the user changes it to improve security. I do not believe that headset is configurable so 0000 should work just fine.
Jun 23, 2009 | Jabra BT125 Headset
Radio Communications Logo
15 people viewed this question
Top Alcatel Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Alcatel Radio Communication Expert? Answer questions, earn points and help others
