Question about Sony MHC-EC55 Shelf System
Disc player wont open
Its stuck and i cant get it open
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
A DVD is stuck in the player and the door will not open, it makes a grinding noise when you try to open it.
well looks like the disc is lodged into the track thats why you cant open it, the grinding noise is the track slipping on the motor gears as it forces to attempt to open and fails..
what we need to do is open this up and remove the disc manually..
  1. unplug the device (dont wanna get electrocuted)
  2. remove the screws to the back and under the player
  3. lift the cover off by sliding it back then raising it up , prying with a bladed screw driver helps.
  4. you will now see the disc stuck under this metal / plastic piece if you can see the disc at all.
  5. remove the screws holding the disc tray top in place. remove the disc and reassemble.
that should solve the problem, let me know how it turns out of if you need more help if you ran into a tight spot.
Apr 05, 2011 | Oritron Televison & Video
My dics dor to its changer wont close
open it up
the tray has somthing stuck init
Mar 02, 2010 | Sony CDP-C445 5-Disc CD Changer
Tray wont open and tuner seems not to work
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Jul 30, 2009 | iLO DVDR04
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
Samsung DVD -VR 357 wont record or playback
Take player apart and clean the lens with a q-tip and alcohol. It is very simple and mine was doing the same thing until I cleaned the lens. DVD or CD lens cleaning does not clean it well enough.
Feb 01, 2009 | Samsung DVD-VR357
Dvd recorder - dvd+rw disc loaded - now stuck on load
turned off the dvd recorder at power outlet. Left overnight. Turned on again in morning and pressed open/close and managed to get the dvd drawer to open. No further problems
Jun 01, 2008 | Pioneer Televison & Video
Govideo r6750 stuck tray
my 10 year old nephew forgot to take a disc out and inserted another this stopped the tray from opening i had to undo the screws holding the cover and remove them .Good luck p.s. don't forget to unplug firse
May 21, 2008 | GoVideo VR3845 DVD Recorder/VCR
Two dvd's stuck in player
you cant get the system to open until repairing it but to get ur cds open ur system and take apart the place where the disc sets to start playing the movie
Dec 21, 2007 | RCA DRC8300N DVD Recorder/VCR
Sony MHC-EC55 Shelf System Logo
41 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
