Question about Dell Inspiron 531s Desktop Computer
Have to restart pc if not using for awhile.
I use to be able to leave my Dell Home Premiun Vista PC on for hours. Now when I hit enter or move the mouse, a black screen with blue running lights above says windows resume. I have to shut the tower off and restart it.
  • 51 Answers
Do two things: 1) do a drive cleanup to remove temporary files. then 2) a scandisk to recover bad and corrupt data. Go to MY COMPUTER RIGHT CLICK the C: drive Choose PROPERTIES Click the DISK CLEANUP button once you get the boxes check ALL OF THEM and let it run. Both the search and the cleanup can take several minutes to an hour or more so be patient. Once that is complete do the same steps as above but instead of disck cleanup choose the TOOLS Tab. Then click CHECK NOW. You will lget an error that asks if you want to do this the next time the pc reboots. Tell it YES then go ahead and restart the PC. This can also take 30-90 minutes to run depending on how much data is on the drive and how bad it may be.
Posted on Jun 14, 2009
Factory restore
Dell Dimension computers have a built-in PC restore system that allows you to quickly restore the PC to its original factory settings.
The PC restore is located in a hidden partition of the PC's hard drive and contains a copy of the computer's original factory installed software.
There are two different ways to restore the Dimension's settings depending on which operating system your computer is running.
Windows XP
Disconnect all peripheral equipment that is attached to your computer such as printer, scanner, external hard drive and memory sticks.
Restart the computer.
After the Dell screen appears on the monitor, hold down the "Ctrl" key and press the "F11" key.
If the Windows XP screen appears before you can finish this step, wait for the computer to finish rebooting and restart the computer again.
Highlight "Restore" in the Dell PC Restore window by using the tab button.
Hit "Enter."
Highlight "Confirm" in the restore warning box by using the tab button.
Hit "Enter."
This will start the system restore process.
Do not attempt to turn off the computer during this process or vital system files may be damages and you will not be able to restart your computer.
Click "Finish" in the box that notifies you that the restoration has been successful.
Hit "Enter" to restart the computer.
The computer has been restored to the original factory settings.
Windows Vista
After the Dell screen appears on the monitor, press the "F8" key.
If the Windows Vista screen appears before you can finish this step, wait for the computer to finish rebooting and restart the computer again.
Highlight "Repair Your Computer" by using the down arrow key in the Advanced Boot window.
Hit the "Enter" key.
Click "Next" after selecting a language. Log into the computer as an administrator.
"OK." Choose "Dell Factory Restore."
Click "Next."
Check "Yes" next to the reformat the hard drive and restore factory settings option.
Click "Next" to start the restoration process.
The computer will automatically restart itself to its original factory settings.
Aug 18, 2013 | Dell Dimension C521 PC Desktop
Why does my pc only start on safe mode
While in safe-mode, open the Start Menu and click "Run"
Type "MSCONFIG" in the dialog box and hit Enter.
Under the boot tab, uncheck the "boot in safe mode" check-box.
Restart your PC.
Oct 16, 2011 | Microsoft Windows Vista Home Premium...
Need to install new mouse but cannot move to the next without mouse
You can navigate with the TAN and ENTER keys. Use the TAB key to select each option. You will see each button get highlighted as you keep hitting TAB. When the correct option is highlighted, hit the ENTER key.
Aug 30, 2011 | Dell Dimension 2400 PC Desktop
During boot up of my dell studio 1537 laptop it just keep repeating the dell studio load screen
If PC is not going further Dell logo screen then most of the time its a hardware issue. You can try only to steps to fix this issue easily.
1.Ran a diagnostic of dell by Cd
insert your dell drivers and utilities disk into your drive>>turn off the comp>>restart the comp by pressing F12 key>>you will boot menu now>>choose the option boot to utility partition>>hit enter>now it will show you 3 test> choose Express test and hit enter>>now it will start checking your hardware component of your computer
2.If hardware diagnostic pass then you can try dell factory rectory restore.
if you have xp they try this:-
1.Turn off the computer>>restart the pc by pressing alt+f11 again and again>>now you will get the dell factory restore wizard and follow the on screen instruction. sometime it does not show you the dell factory Restore screen in case if it is damage or corrupted.
hat screen if
If you are using Vista or window 7 then follow this:-
  1. Restart the computer. To do this, click Start, click the arrow next to the Lock button, and then click Restart.
  2. As the computer restarts, press the F8 key until the Advanced Boot Options menu appears on the screen.
  3. Press the downarrow.jpg(Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
  4. Specify the language settings that you want, and then click Next.
  5. Log in as a user who has administrative credentials, and then click OK.
  6. Now you will get Recovery Tool so here Choose the last option dell emergency backup/factory restore
7.Hit enter and next and next and enter your personal information like country, user name, language etc....and finally you will get you desktop welcome screen.
cheers!
Let me know was this helpful.
Mar 22, 2011 | Computers & Internet
How can i restore my dell dimension to factory setting
to restore the settings you have to follow the steps
Instructions
    Windows XP
  1. Step 1 Disconnect all peripheral equipment that is attached to your computer such as printer, scanner, external hard drive and memory sticks.
  2. Step 2 Restart the computer. After the Dell screen appears on the monitor, hold down the "Ctrl" key and press the "F11" key. If the Windows XPmag-glass_10x10.gif screen appears before you can finish this step, wait for the computer to finish rebooting and restart the computer again.
  3. Step 3 Highlight "Restore" in the Dell PC Restore window by using the tab button. Hit "Enter."
  4. Step 4 Highlight "Confirm" in the restore warning box by using the tab button. Hit "Enter." This will start the system restore process. Do not attempt to turn off the computer during this process or vital system files may be damages and you will not be able to restart your computer.
  5. Step 5 Click "Finish" in the box that notifies you that the restoration has been successful.
  6. Step 6 Hit "Enter" to restart the computer. The computer has been restored to the original factory settings.
  7. Windows Vista
  8. Step 1 Disconnect all peripheral equipment that is attached to your computer such as printer, scanner, external hard drive and memory sticks.
  9. Step 2 Restart the computer. After the Dell screen appears on the monitor, press the "F8" key. If the Windows Vistamag-glass_10x10.gif screen appears before you can finish this step, wait for the computer to finish rebooting and restart the computer again.
  10. Step 3 Highlight "Repair Your Computer" by using the down arrow key in the Advanced Boot window. Hit the "Enter" key.
  11. Step 4 Click "Next" after selecting a language. Log into the computer as an administrator. Click "OK." Choose "Dell Factory Restore." Click "Next."
  12. Step 5 Check "Yes" next to the reformat the hard drive and restore factory settings option. Click "Next" to start the restoration process. Do not attempt to turn off the computer during this process or vital system files may be damages and you will not be able to restart your computer.
  13. Step 6 Click "Finish" in the box that notifies you that the restoration has been successful. The computer will automatically restart itself to its original factory settings.
thanks
May 18, 2010 | Computers & Internet
My dell vostro vista home basic won't come on will start loading for a sec and go off.
Hi... Try this: Turn the pc on and press F8 when you see the Dell screen. Select Safe mode and press enter. click start and type msconfig on start up search field and press enter.
Disable all start up items on the start up tab and check your antivirus software. Click ok and restart the machine.
Hope this will help... ^_^
May 18, 2010 | Dell Vostro 1500 Notebook
Toshiba satellite laptop doesn't work after ipod removal
format and install a new operating system..start fresh
Apr 04, 2009 | Toshiba Equium 100 PC Desktop
Can not get into safty mode get floppy diskette seek failure i have a dell dimension 5150
restart the pc and press F2 immediately after the dell logo comes on.
go into BIOS and disable the floppy drive. exit and restart the pc.
Feb 23, 2009 | Dell Dimension 2400 PC Desktop
Trying to restore Dell Inspiron 1501 to factory settings.
don't hit ctrl, f11 instead hit F8 and then go into Dell Factory Image Restore, that will wipe, format and reinstall all the factory software that's stored on the Recovery Drive (usually the D: drive) good luck.
http://virusremoval.vpweb.com
New York
Jan 27, 2009 | Dell Inspiron 1501 Notebook
Windows Vista Home Premium will not let me open PNY Optima Pro Attache 4GB
the files from XP may or may not be readable on vista...and I can assure you vista files will not read on xp..
recommend you get two of those.
no guarantees of interchangeability from xp to vista(why am I not surprised?)
check your computers' warranty here for FREE
Mar 02, 2008 | Computers & Internet
Dell Inspiron 531s Desktop Computer   Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
