Question about Easy New Arrival TT-028 Portable Mini Multimedia Speaker with FM Radio /LCD screen /SD Slot /Line-In /USB Jack - Blue
Tt-028 wont play usb music files
When i plug in my flash usb drive my tt-028 says no????
How do I play music on a flash drive with the Pyle PWMA220BM? My keeps switching to Bluetooth mode instead of staying in USB mode.
You can connect a USB flash drive to the USB A port (A) directly.
You can also use a commercially-available USB cable to connect a USBdevice.
Music stored in a USB flash drive connected to the USB A port (A) can be played back using the supplied remote control, or by a smartphone/iPhone that has SongPal installed.
You can play back high-resolution audio format files by connecting a USBflash drive of Hi-Speed USB standard or more, to the USB A port (A). For details on file formats, refer to the operating instructions supplied with your USB flash drive.
http://helpguide.sony.net/speaker/srs-x99/v1/en/contents/TP0000634048.html
Jul 02, 2018 | Pyle Car Audio & Video
Have a pioneer truck stereo. When I plug in my memory stick into my USB it plays a couple of songs then I get a error 19.
USB Flash Drive - Issues With Music In Car - Need to format to add ...
www.neowin.net > ... > Hardware Hangout
NeowinAug 11, 2014 - My Radio can see the USB drive and plays the music directly from it. ...drive, after that plug it in your car stereo, play a few songs randomly, disconnect, ....The index file should stick out like a sore thumb amongst your mp3 files. .... I haveripped some CDs into my computer, and then synched them to a flash ...
How to Format a USB Thumb Drive for Your Car: A Solution ...
doughaslam.com/.../formatting-a-thumb-drive-for-your-car-a-solution-to...
Nov 4, 2010 - Not being an iPod owner, I use it to connect a thumb drive that is big enough to ... There were a few obstacles to getting this just right, however, and I thought I ... I renamed the files (once copied to the USB stick, never touching my ... I could cram more info into the short car stereo display (the example in the ...
#234 - My USB flash drive shows as unsupported in my ...
? 1:19
https://www.youtube.com/watch?v=MgaZwtmbuA0
May 29, 2013 - Uploaded by hondadailytv
My USB flash drive shows as unsupported in my Honda vehicle. ... WMA or AAC when a USB flash memory device is playing. The USB .... Format USB via FAT32 file system and then Uploadsongs in mp3 format and plug into your car and .... I would haveto move/delete all my songs from the USB stick and ...
Jan 21, 2016 | Pioneer Car Audio & Video
Can't get the usb port to work
If you expect the music files on the flash drive you plugged into the USB port to start playing by themselves, good luck with that. You have to open a media player application (say Windows Media Player), open the removable disk that is your flash drive from within the application, select an .MP3 file from the flash drive and play it.
Feb 03, 2015 | Audio Players & Recorders
Playing music loaded to USB Flash Drive on stereo
Check that your system is compatible with the file. You may have to convert files.
Sep 07, 2017 | Pioneer DEH X3500UI - radio / CD / MP3...
Trying to play flash drive in USB port on stereo
Make sure that the music files are indeed mp3 format. An iPod will play several different formats but most av head units only play mp3. A lot of the songs that are downloaded from iTunes are actually mp4
Jun 08, 2014 | Pioneer DEH X3500UI - radio / CD / MP3...
I want to be able to listen to music in my car using my USB Sandisk Cruzer but my car only accepts an iPhone plug into an Aux hole. Is there anyway I can by pass this
You might be able to using one of these usb to audio lead you can also get these just as adaptors without the need to for a lead http://www.ebay.com.au/itm/3-5mm-Jack-Plug-to-USB-Male-MP3-Mp4-Audio-Data-Cable-White-/330831058200?pt=AU_Electronics_Portable_Audio_Accessories&hash=item4d07115518 $4.12 3.5mm Jack Plug to USB Male MP3 Mp4 Audio Data Cable White or http://www.ebay.com.au/itm/USB-Male-to-3-5mm-Audio-Stereo-Headphone-Jack-Plug-Cable-For-MP3-MP4-Black-/160733005608?pt=UK_Computing_Sound_Vision_Audio_Cables_Adapters&hash=item256c6f0728 $1.50 free postage You might get these on Ebay im not sure which country you are in this might guide you to one You could get this on Ebay if you dont have an account you will need to create one. https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo Add Email adress Add Bank Acc Add Credit Card also Add your Postal Adress also Add a PayPal account. Click on the Ebay tab on top of page from the drop down list you will see specific pages. On left hand side on Ebay summary page you will see the PayPal link. when you get to the PayPal login page at the bottom you will see new to paypal sign up tab. Paypal to create an account PayPal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a Postal Adress. Be very specific when you type in the search. Always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described. You will even see the pictures of your item so you cant make a mistake and get them home delivered. Music has become more mobile than ever before, as numerous devices can store and play music on-the-go. Companies have developed car audio decks that incorporate USB ports in the faceplate. This allows flash drives to be plugged into the deck, and music on the drive to be played. Flash drive format issues are minimal, considering nearly all flash drives are formatted in the FAT32 file system by default. FAT32 is readable by any operating system, or stereo deck with a USB por
Determine if the stereo deck in the vehicle is capable of playing music off a USB flash drive. Read the stereo deck user's manual, or inspect the deck faceplate for a USB port. Plug a USB flash drive into an available USB port on a computer. Check the drive to make sure there is enough available space for music files. Using Windows, double-click the desktop icon labeled "My Computer." Right-click the flash drive icon, and select "Properties." Capacity will be shown. Using Mac, click the flash drive icon once it appears on the desktop. Click "File" in the top menu bar, then click "Get Info." A dialog box appears, and capacity is listed. Drag and drop any desired music files onto the flash drive. Be sure the files are in .mp3 format. Although some stereo decks are capable of playing other music types, the .mp3 extension is universal and all decks will play it. Spend a short amount of time organizing the files into folders. Organize by genre, artist, or create mixed playlists. Selecting music while driving will become much less distracting. Close the drive window, and safely eject the flash drive from the computer. Plug the flash drive into the stereo deck of the vehicle. Select the USB port as the music source, via the stereo deck. Read the manufacturer's user manual if unsure of how to change the source. Adjust the volume, listen, and enjoy. Hope this helps.
Jan 15, 2013 | SanDisk Cruzer Electronics - Others
Bought 4gb sandisk cruzer flash drive stored music from computer but it won't play the music on the car fm transmitter
a flash drive is used mainly for storing of files, you need a device that will play the files you want, in this case a device that plays mp3s and either transfer your music to/through it.
Unless your transmitter states that it plays different media formats that is but i have never heard of that before.
hope this helps.
Dec 08, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
WHEN YOU PLUG IN THE FLASH DRIVE TO A COMPUTER USB PORT WHAT DO YOU DO IN ORDER TO PLAY MUSIC??? i know a box comes up which says what do you want to do, view files & etc but do not know how to play...
If the autoplay menu doesn't show up, just go to My Computer and double click whichever drive the USB is in. If it does, just view the files, then find and double click the music files you have in the flash drive. It should open whatever music player you have on your computer and play the music.
Hope this helps.
Jul 27, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
I have installed the receiver and it played the music from my USB flash drive very well, but few days ago it stopped playing (displaying NA files)...then it's not recognizing that the flash drive is...
JUST PRESS THE RESET BUTTON, SITUATED NEXT TO THE USB PLUG.
IF ALL THE CONNECTIONS WERE OK, IT SHOUD REINITIATE THE KDC-MP438U AS PAGE 3
OF THE MANUAL. YOU WILL HAVE TO READJUST THE CLOCK.
CLAUDE
Jan 12, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Easy New Arrival TT-028 Portable Mini Multimedia Speaker with FM Radio /LCD screen /SD Slot /Line-In /USB Jack - Blue Logo
81 people viewed this question
Top Easy Audio Players & Recorders Experts
Tom Chichester
Terry
Terry
Badre Errguibi
Badre Errguibi
Level 1 Expert
Are you an Easy Audio Player and Recorder Expert? Answer questions, earn points and help others
