Question about Nordic Track GX 4.5 Cycle
Eddy mechanism slips
From the time it was new the recumbant bike would occasionally break loose and turn freely when it was in use. It happened more often and now will not hold for even one turn. The problem seems to be on the shaft of the eddy mechanism. Apparently, whatever makes it hold when peddled forward is not catching well enough to hold under even light pressure. The bike cost about $400, but Nordic Track wants $465 for a new "eddy mechanism". It seems like it must be just a small part of the inner shaft that is causing the problem.
maxtreadmill
  • 832 Answers
SOURCE: Nordic Track treadmill trips GFI.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the GFI to trip. simple test start the treadmill do not walk on a see if the GFI is tripped in it does trip then lubricate, then if after lubricate it still the you have a worn belt and possibly damaged deck depending replacement price and on what you paid for the treadmill it may or may not be worth fixing.
Posted on May 20, 2010
  • 218 Answers
SOURCE: how do i raise nordic track treadmill?
if that is where it catches then that is how far it goes there is no adjustments. Make sure the incline is the whole way down
Posted on Aug 11, 2010
SOURCE: nordic track c1900 catches everytime u walk or run
swflafitness - Your suggestion worked perfectly for me, thanks!
Posted on Nov 13, 2010
  • 3 Answers
SOURCE: My Nordic Track A 2050
Have you tried adjusting the rear roller bolts with an allen wrench? That usually works for me.
Unfortunately now I have a slipping problem that tightening the belt via the roller bolts doesn't fix. In fact, I feel as if the belt is too tight as it only lifts about 2" instead of the recommended 3-4". Hope we get some other ideas here!
Posted on Dec 21, 2010
SOURCE: our belt is slipping on our nordic track c1900
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Posted on Jan 03, 2011
Petals turn freely with no resistance... is there a chain or belt?
if the pedals are direct to the wheel , there will be no chain
if the pedal arms are back from the wheel , it will be a chain which has probably broken or come off the cogs under the covers
The fix will be to remove the covers and see what has happened
Dec 31, 2015 | Schwinn 220 Recumbent Exercise Bike - 2012...
How can I fix the slippage in my Schwinn 215 recumbent bike pedal?
Problem is in the back wheel or the "freewheel" The replacement of this part is recommended but it requires special tools. Take your bike to the local bike shop for this problem.
Sep 13, 2014 | Cycling
Schwinn 220P no resistance
see this steps and fix it. God bless you
  • 1
    Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2
    Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • 3
    Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4
    Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5
    Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Nov 23, 2012 | Schwinn 220 Recumbent Exercise Bike - 2012...
    What's better a recumbent or an upright exercise bike?
    Recumbent bike works best for elderly people with back and hip problems because of the relaxed position and the angle that put's less pressure on those areas. Upright exercise bike works on more areas than the recumbent bikes including the lower abdominal muscles.
    Aug 09, 2012 | Exercise & Fitness
    Black smoke coming from exhaust occasionally.
    Black smoke is indicative of carbon or incomplete combustion caused by either poor ignition (weak spark) or too much fuel (choke setting). Check out these areas.
    Mar 31, 2017 | 2003 Suzuki VL 1500 Intruder LC
    The tension does not increase on my schwinn 220
    adjust the magnet very well, tigh the bolts if there loose the tension will be not o.k
    Apr 24, 2012 | Schwinn 220 Recumbent Exercise Bike - 2012...
    The bike goes to Pause mode frequently throughout the workout. I have tested all the exercise modes and made sure my RPMs stay the same but it just flips to pause and then starts working again...
    Star Trac Pro Upright Bike Owner's Manual - ManualsLib
    www.manualslib.com > ... > Exercise Bike > Pro Upright Bike
    Exercise Bike Star Trac Upright Sport Bike Owner's Manual. Stationary sport bike (28 pages) ... Pro Upright Bike Pro Recumbent Bike ' W N E R A N U A L..
    Jan 20, 2011 | Star Trac Sport Recumbent Exercise Bike
    Purchasing a 514 currently have a rt1000
    514 is definite upgrade to Nr 1000 with walk thru feature and adjustable lumbar support instead of magnetic boot resistance it is using eddy current resistance.
    May 03, 2010 | Nautilus Nr Recumbent Exercise Bike
    Our life fitness 9500hr recumbent bike stopped working
    If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
    HERE IS THE PROCEDURE TO REPLACE THE BATT:
    Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
    Apr 17, 2010 | Life Fitness 9500RHRT Recumbent Bike
    Nordic Track GX 4.5 Cycle Logo
    70 people viewed this question
    Top Nordic Track Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Ross Metcalfe
    Ross Metcalfe
    Electro Med Services...
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
