Question about Tefal UltraGlide plus 1656 Iron
When I plug the iron in it does not heat up. It had never been dropped.
Not heating what will be the problem
if it is not heating up -- the problem could be a few things,, it could be a bad cord / connection ( at the iron side or at the plug side ),, it could be a bad switch ,, or it could be a burned out heating element. if you have a volt meter ( or know someone that does ) - you can do a few test to the wiring and see what the trouble is.
if you need further help -- please feel free to write me back here and I will walk you through the steps the best way that I can. but if you do not have a volt meter - then just drop it off at your local small appliance repair shop and for a small price I am sure they can fix it quickly -- if it is just a loose wire or bad plug - the cost will be about 10 to 15 dollars ( depending on where you live ).
c...
Feb 23, 2011 | Panasonic NIA56NR NI-A56NR Iron
When I plug it in and turn it on it doesn't heat up.
The heating element is broken. This is caused by dropping or banging the device.
Sep 21, 2010 | Conair Professional Ceramic Hair...
We dropped the iron off the ironing board onto the floor, and now it won't heat up.
We located a Black & Decker Service Center here in our town and will be dropping it off tomorrow.
Dec 06, 2009 | Black & Decker D2030 Iron
Iron won't heat up.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Nov 02, 2009 | Panasonic NI-A57SR Iron with Auto Shut-off
My iron is not heating. Yes, it is plugged in a
hello mam
please change the thermostat of the iron and also check the heating element.
Oct 02, 2009 | Irons
Sunbeam steam iron 4239 adjustable steam iron won't heat up
POSSIBLE CAUSES:
1. Blown fuse
2. Broken thermostat
3. Broken power cords
4. Broken heating elements
first of all check FUSE.
good luck...
Apr 06, 2009 | Sunbeam Irons
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
Rowenta iron manual needed
If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
Jul 24, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Why isn't my Iron heating up? Just finished filling my Krups V65 iron with water. Was ironing linen shirt on linen setting, all of a sudden, heat dropped all the way down to light one (very low heat) and...
I do believe the thermostat is defective.All the iron have a small thermastat top control the temperature and is working like a switch.If the switch don`t work get stuck on the same position.Unfortunatly sometimes is better get a new one themn fix an old one but this is The Market and nothing i can do personally.Also make sure the thermostat knob is working properly.If you hear a click when you turn is ok.
Good Luck
Jun 12, 2008 | Irons
Rowenta Effective Iron - Model DX1700-U1 NRB01-01
I just drop it a few times on the floor really hard a few times and then it gets hot again!!!
May 16, 2008 | Rowenta Powerglide DM273 Iron
Tefal UltraGlide plus 1656 Iron Logo
Top Tefal Irons Experts
Henry  Thomas
Henry Thomas
Are you a Tefal Iron Expert? Answer questions, earn points and help others
