Question about Airspeed Revue Thommen Altimeter 5360001 Wrist Watch for Men
Where can the altimeter of a revue thommen airspeed watch be repaired ?
The arm of the altimeter doesn't move
I have a Suunto X-Lander and i dont get along with the barometer/altimeter. The barometer always shows about 2 mbar below the nearby airport homepage. Can i by myself calibrate the sensor? This even...
Erik, the altimeter uses barometric pressure to determine changes in elevation. Rule one is whenever you know the elevation for a fact, adjust it as the barometer is changing often and therefore affecting the altimeter reading. The only sure way to avoid this is use GPS. Altitude is derived from locating 3 or 4 satellites in a geo syncrohnus(SP?) orbit. Pilots always reset the altimeter before take off and you should too. Find elevations on road signs, maps, etc.
May 24, 2011 | Watches
The stop /reset button has dropped out of my Timex Expedition T41501 Altimeter Watch. Where can I get a spare and is it easy to fit? John Polak United Kingdom
Thank you for contacting FixYa.<br /> Im sorry, but you will have to send into Timex to get this repair. This is not a repair that a novice can do,<br /> I did find you a link to a repair site in UK. Best regards. Jewel<br /> <a href="http://www.timex.co.uk/contact_us.aspx">http://www.timex.co.uk/contact_us.aspx</a>
Aug 26, 2010 | Timex Adventure Tech Altimeter 41501 Wrist...
The stem pulled out of my airspeed day date auto- what to do??
Dont try to put it back in yourself...put the watch and stem in a plastic baggy and take it to a reputable watch repair shop. Its too easy to slip and miss the hold that the stem goes into and you can do some other damage to the movement!
Jan 19, 2010 | Airspeed Revue Thommen 8516002BBLUE Wrist...
How does the altimeter function work? we can't find it on the enclosed instructions
Altimeters on watches are usually based on barometric pressure, since the pressure changes all the time you generally need to adjust the altimeter to a known altitude. You can look on USGS website to find the altitude of your area, or simply type in "altitude of city, state" in a search engine.
I hope I understood your question; if not, please reply.
Oct 17, 2009 | Timex Adventure Tech Altimeter 41501 Wrist...
T touch Meteo out by 20 Milibars
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the
watch. This will also calibrate the Meteo.
To calibrate the Altimeter:
1. Activate Crystal
2. Press Altimeter
3. Press and hold top + button until the watch beeps and display flashes.
4. Use + and – buttons to adjust altitude
5. Press center of dial to lock in.
Oct 14, 2008 | Tissot T-Touch T33159851 Wrist Watch
Setting the altimeter on the la crosse xg-55
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
Sep 03, 2008 | La Crosse XG-55 Wrist Watch
Tissot T-Touch Baro way too high
Try to recalibrate the Baro/Altimeter as below:
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the watch. This will also calibrate the Meteo.
1. Activate Crystal
2. Press Altimeter
Aug 05, 2008 | Tissot T-Touch T33159851 Wrist Watch
Casio Protrek PRG-70-YT
wait until the battery is full reloaded
Jul 08, 2008 | Casio PRG-40T-7 Pathfinder
Freestlye altimeter watch instruction manual
you should go to a watch store where you got it from and ask for on
Mar 31, 2008 | Watches
Airspeed Revue Thommen  Altimeter 5360001 Wrist Watch for Men Logo
Top Airspeed Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Airspeed Watch Expert? Answer questions, earn points and help others
