Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Scan to usb drive
Scan to usb memory stick
  • Konica Minolta Master
  • 6,161 Answers
C250 NO
Posted on Jan 10, 2016
Miracle arm automatic gate opener
Recovering memory stick data can be tough, you can try recuva (http://www.piriform.com/recuva). This is a very good tool for recovering data, it includes a quick scan and a deep scan.
If the recovery works or you decide the data doesn't matter or you wish to use the card again, then to format it (this will delete EVERYTHING on the card) for normal use then the HP USB disk storage format tool is the best for this, I know it says USB, but it works for cards too: http://en.kioskea.net/download/download-127-hp-usb-disk-storage-format-tool
Be careful when using this tool, ensure you have the correct drive letter selected.
Nov 11, 2013 | Electronics - Others
I have lost the instruction to the memory stick and have no idea how to use it. The password etc is blanked out when you plug it in
im not sure what you wat to do or are referring to if you are try to remove the password download dr freeware i have never used or had to use it it reads like it can remove passwords from any usb drives and if you are trying to use it but dont the basics
insert this drive into a usb slot
click start click on my computer you should see your usb drive or
click start all programs accessories open windows explorer navigate to your usb memory stick then go to the information you want to back up select the information right click select copy then back to memory stick select then right click select paste
or select the imformation hold the cursor on then drag it to the memory stick and drop it into it
or select the imformation right click and send to the memory stick
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps you
Jul 28, 2011 | Maxell 8GB USB 360 USB 308 - 503202 Hard...
I have formated my sony memory stick pro duo.but now it is showing no space and i could nt take any photos or i cant copy anything.kindly let me know any solution if you have?
again format the memory stick and after that scan it with anti virus. it probably have virus on it. and check if it is not under moist condition or it will effect the memory stick.
Apr 03, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Virus of my usb
Use your virus scanning software to scan and remove the virus on your USB memory stick.
OR
Use a WEB base virus scanning to remove the virus on the USB memory stick. Please click on these links to access these WEB-based Virus Scan sites :-
Trend Micro housecall
http://housecall.trendmicro.com
symantec - Norton Security Scan
http://security.symantec.com
Feb 11, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My memory stick is write protected...i cant add/delete files.
CHECK if it is not physically protected, a small button/switch might be on the stick!
THEN, try any other flash drive or memmory stick to locate the target problem (memorry stick, or usb port mulfunction or even security/driver issue).
PLUS, there are some programes that might protect flash drives, check if u have any, and uninstall them, and make sure u have deleted ther HIDDEN system files located on the stick!
gd luck.
Jan 01, 2010 | Electronics - Others
My daughter is creating a powerpoint but cannot save onto a memory stick
Make sure that you formatted the drive. It could be the memory stick has a virus on it. I would scan it using a popular virus scanner from nortan or macafee.
Nov 09, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
My memory stick pro duo would read system file error. what does it mean?
it is infect by virus, scan it with updated cleaner and format it.
Aug 06, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Pen drive not getting detected? how to work it?
first go to my computer propery then hardware then device manager then go t ousb controller uninstall all usb drivers from there then just right click on any driver then click on scan for hardware changes then it automatic install usb drivers .
Connectyour pen drive to usb port check all port.
then if its not working check with other usb device is working with usb port?
Jul 15, 2009 | Iomega REV ATAPI HDR B/U KIT CA 6 REV...
Downloaded Frostwire to a memory stick, can't delete folder.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Apr 19, 2009 | PNY 2GB microSD Memory Card
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
20 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
