Question about Kitchen Appliances - Others
Marca john italian bread
Formulation
Can I put 5-20 synthetic oil in a 1997 Toyota car
Provided you use the correct grade of oil as stipulated by Toyota for your engine(you have NOT identified your model and engine)(check your owners manual) and provided you use the formulation suitable for Toyota engines you will be fine using the correct grade fully synthetic oil. There are sometimes 2 or 3 different formulations in exactly the same grade for some oil brands so make sure you select the correct one.
Some oil companies offer oil selector programs for customer use on their web sites so if unsure use these systems to ensure you are using the correct oil..
Apr 05, 2016 | Toyota Cars & Trucks
Hi. What type of oil do I use on my Ford Econovan y.2000. The engine is FE2000
You can use a 10w-40 grade premium oil or synthetic blend oil
.....OR.....
a fully synthetic in 5w-30 grade which is better but more expensive.
When selecting the oils in either grade make sure the one you choose is approved for Ford vehicles by checking the label details. Oil companies manufacture 2 or 3 different formulations of oils in the same grades and the label (usually the back label on the pack) will indicate that the oil is formulated for the engines of specific car manufacturers.
Jan 02, 2016 | Ford Cars & Trucks
I have to do homework and I don't now what hypothesis means
A hypothesis is a possible answers to a scientific problem you have been studying. Say you have carried out some observations on some phenomenon, done calculations tried to find some regularities. Then come the question why is it doing this? Now is the time to formulate a hypothesis. It describes what you think is happening. It is some sort of a guess (after having done some experimentation), not right after the title of your lab report. Once a hypothesis is formulated you devise some further experimentation to test it.
Aug 11, 2014 | Computers & Internet
15w40
Hi John, These days most oils are formulated to be used in both petrol and diesel engines but those formulated specifically for diesels should not be mixed. If your talking of a top up I suggest a flush with a good quality chemical and a lub service. If you have had a service carried out and changed the type of oil the same applies. Mixing oils can cause fast sludge build up which can block the filter, oil pump and galleries. These days most oils are designed to run both types of engine, but mixing is neve a good idea. Regards John
May 01, 2013 | Cars & Trucks
What's the pretreatment phase in the freeze-drying process?
The pretreatment phase includes concentrating the product, adding components to increase stability. In many cases the decision to pretreat a product is based on the theoretical knowledge on the freeze-drying process. There are many method of pretreatment including freeze concentration, formulation to stabilize reactive products, formulation to Increase the surface area etc.
Aug 09, 2012 | Camping, Backpacking & Hiking
What kind of transmission fluid does a 2006 PT cruiser use
Hello there
Your manufacture recommends
Coastal ATF+4 is formulated for Chrysler automatic transmssions where ATF+, ATF+2, ATF+3 or ATF+4 is recommended.
  • Improves low temperature fluidity and viscosity breakdown performance
  • Formulated to give full protection in Chrsyler transmission operation
  • Anti-shudder durability
  • Recommended and licensed for all transmissions that call for ATF+4 fluid
Jan 23, 2011 | 2006 Chrysler PT Cruiser
When is the formule for transformer 1.5 kva to amperes
To convert KVA to AMPS:
Multiply KVA by 1000/voltage (KVA x 1000) / E
May 18, 2010 | Electrical Supplies
I was told to use only HE detergent, is this true? Frigidaire front loader. My first. What happens if you use regular detergent?
the he detergent is a softer compuond, thus disolving easier, also has an alge reducing compuond, reducing the risk of mildew and unpleasant smells, if you use regular soap, you r asking fo plugged water ports.
Nov 19, 2009 | Washing Machines
What is meaning for absolute nodal coordinate formulation? how to apply damping force into absolute nodal coordinate formulation?
Must be a China made Mill. Their English does not make sense.
I assume it is referring to taking looseness out of a slide or moving part by adjusting the ways or clamps very gently.
Jul 23, 2009 | Wmh Tool Group Jet 350017/JMD 15...
How to formulate log function with excel
Here try this link
http://support.microsoft.com/kb/214116
Nov 12, 2007 | Microsoft Excel for PC
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
