Question about Magnavox ZV427MG9 DVD Recorder VCR
Dvd door and vcr/dvd source button do not opperate
Because source button or dvd door does not operate by remote or manually, the unit can not dube or play dvds.
How to operate with remote control
VCR Remote Control Buying Guide ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls
Finding a suitable VCR remote control to operate a combo unit involves finding a remote that supports the functions of each component of the unit. The key to ...
REMOTE CONTROL MANUAL Synergy V - RCN
help.rcn.com/pf/12/webfiles/files/ONNET6907/remotes/RC.../index.htm
Jump to Operating In VCR mode - Your remote control is designed to operate many functions of your VCR. To select your remote's VCR mode:.
Program and Operate Your Cox Remote Control
www.cox.com/business/support/.../article.cox?...
Cox CommunicationsApr 28, 2015 - ... on how to operate and program the buttons on your remote control, select from ... Index of Remote Controls ... Program TV, DVD, VCR, Stereo.
VCR remote control codes ' FiOS TV ' Residential Support ...
Jan 14, 2016 | Televison & Video
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=sansui+VRDVD4005 .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
Just hooked up my new Magnavox DV220MW9 DVD Player ? VCR Recorder. I was able to set the time and a vcr timer program but now I can't switch the source. It now comes on as the DVD but neither the remote...
You need to release the timer to access the VCR. Press the Timer Set button on the remote or the Stop/Eject button on the recorder. Then press the VCR button.
Please note: the scheduled recording will not run as programmed unless you press the Timer Set on the remote again. (The timer locks the VCR until the scheduled ON time.) The DVD player is controlled separately and becomes the default unit.
I hope this helps.
Oct 04, 2010 | Philips Magnavox DVD/VCR Dual Player
Unable to operate recorder at all.
When you are turning the recorder on it is blocking the signal for cable going to the TV. Your TV will need to be on channel 3 or 4 depending on what the dvd/vcr player channel output is set to. This is why your tv is asking you to re-scan. It is losing the video signal because the dvd/vcr is taking over. The reason why the vcr with the button on the remote is because the vcr button is changing the function of the buttons on the remote to vcr. Even though the dvd/vcr is one unit they still will act like two seperate components independent of each other. They have seperate power buttons and the dvd player part may need to be hooked up seperately with rca cables to work.
Sep 26, 2009 | Daewoo DVRS05 DVD Recorder/VCR
When I press the TV/VCR button on the remote, the picture on the TV becomes fuzzy and we see no signal from the DVD player. The first sign we were having trouble was that we couldn't set the time...
The TV/VCR button is usually not a function of a DVD player itself.
Normally this is a button on VCR remote controls that allow you to switch between whats playing in the VCR or whats coming in from the 'air/cable signal' from the cable or antenna wire on the back.
If this is a VCR/DVD player combo unit it would appear that the TV may be on the wrong channel for proper operation of the VCR functions (ch 3 or 4 are usually the selectable option on the back of the unit).
Make sure your DVD player is plugged into the correct input on the TV(video 1/svideo/or component ) and the TV is tuned to that same input. If the TV is on the correct input then the TV/VCR button shouldn't do anything at all which is normal operation when watching a DVD. If this doesn't clarify please reply with the model # of the unit. I would be happy to help more.
Aug 05, 2009 | Panasonic Televison & Video
Vcr unit stuck in safe mode
Turn on unit. Press "lock" on remote (third from left bottom row.) Display on unit should say safe off.
Sep 02, 2008 | Televison & Video
DVD door won't open
try using a knife without the dvd player plugged in that will get out the cd
Sep 22, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD door will not open
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox ZV427MG9 DVD Recorder  VCR Logo
14 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
