Question about The Singing Machine Singing Machine STVG1009 Pedestal Karaoke System Tower Speakers Camera Monitor and Radio
CD players not working
CD player not working
One cd player wont read
Take a can of compressed air and blow into the player all around and try it. The heads get dirty over time and stop reading. Clean the dust off the laser head and they usually start working again.
Feb 28, 2013 | Numark Industries Numark CDN 22 Mk4 Double...
Numark cdn25 dual cd player when open close the lcd screen gets dim
Are you using the original factory power supply? That sounds like it isn't strong enough. The mA is what I mean.
Feb 28, 2013 | Numark CDn25 Professional DJ CD Player
We are a group that sings with accompaniment Trax. We use CD's. What type of player do I need to get a good professional sound?
Well, even a walkman type CD player will have the same CD quality as the most expensive professional DJ player. You can get a little stereo to WYE cable to go to your PA... The disadvantage of the small players are the abilty to que up certain tracks and discs. If you need random track selection and shuffling you will find that most any of the home consumer CD players will have the same audio quality... so pick one that you can do the selections with whatever ease you need. Hint, there are a LOT of CD players at the thrift shops... you can get them for nearly nothing and find a suitable one. Most of those you will need cables with RCA plugs at one or both ends and maybe 1/4 inch plugs at the other depending on whether you want to go into certain channels of the PA.
Sep 17, 2011 | Behringer PMP2000 800 Watt 10 Channel...
I'm trying to burn a song to a CD-R using a Boss BR 1180 but every time it completes, there's no song on the CD. I record, bounce, record on 9/10, then try to write to CD and it never works.
"it never works"... this is NOT enough information for us. You are not telling us how the CD is tested. If you are testing it in a boombox type player, that is not a test. First thing is to look at the bottom of the CD to see if you can detect written tracks... with right lighting you can tell if it has been burned. REMEMBER that CD's, unlike phonograph records, are written from the middle outward. Many consumer players have trouble playing CD's that are written but not "finalized". If you CAN see written area (compare to unburned CD) then likely the burning is taking place, and the problem is the format is either not complete or incompatible with your player. Try reading the disk in your computer. Also you might want to visit the forums for the Boss/Roland workstations at VSPLANET.com.
Aug 19, 2011 | Boss Micro BR Digital Recorder
A cd is stuck inside my numark nd400 tabletop scratch cd player
Only safe way is to take covers off to get to the player. A common problem is jamming by a label that came off OR the little belt that drives the carriage has deteriorated or failed. Only way in either case is to open the unit.
Jul 11, 2011 | Numark Industries Numark NDX400 Tabletop...
Can a dvd player be installed in the mpc 4000
The unit is designed for a CD unit. While a DVD player MIGHT work as a CD read and burner, it would not likely burn DVD's or read them.
May 28, 2011 | Akai Mpc2500 Music Production Center
Top console is not working on Pro 1000 Dual Scratching CD Player
Check controller cable between base and remote. Look for bent pins. If appears ok, you may have an internal loose connection. Try and narrow down if loose section is on base or remote. You could have it resoldered if needed. digitalrepair@hotmail.com
Apr 21, 2010 | American Audio Dcd Pro 1000 Dual...
My staton cd play reads no disk
try using a cleaning disk, but ive found that those dont work that well, find the laser lens "near the motor that spins the cd" and use a micro fiber cloth, or eyeglasses cleaning cloth and gently wipe the lens in one direction, you can use rubbing alcohol on the cloth if you like, just blow on the lens to make sure its complely dry. if that does not work, then the laser may be burnt out.
Jan 14, 2010 | Stanton C314 Tabletop CD and Mp3 Player
NO Disc
The first step is to clean the lens of the player using a cotton swab and alcohol. If that failes to resolve the problem, it is likely that the optics are starting to fail and need to be replaced.
Please clean the lens and update this with the results.
Thanks,
Dan
Aug 11, 2009 | Stanton C314 Tabletop CD and Mp3 Player
The Singing Machine Singing Machine STVG1009 Pedestal Karaoke System Tower Speakers Camera Monitor and Radio Logo
26 people viewed this question
Top The Singing Machine Music Experts
Michial Gueffroy
Are you a The Singing Machine Music Expert? Answer questions, earn points and help others
