Question about Sharp el-531x scientific calculator
Turn off the fix mode
Calculator is showing all zeros
    Scholar:
  • 74 Answers
Press SETUP and choose 0 for FSE. Then choose 3 for Norm 1. This will put the calculator back to the original setting.
Posted on Nov 26, 2014
The words FIX DEG appear on the screen and I can't get rid of it. It doesn't calculate properly
DEG says that the angle unit is set to degrees. You can change it to RADians, or GRADs. However much you want to get rid of all of them you will always have one of them. Learn to live with them.
FIX says that the decimal displays will always show a fixed number of decimals. You can decide how many you keep. Apparently your calculator is configured not to show any decimal digits: the number of fixed digits is set to zero. Change it to some other number
There are other display formats : Engineering ENG, and Scientific (SCI)
There is another format (possibly 2) called Norm 1 or Norm 2.
Set you calculator to one of the Normal formats.
Press SHIFT MODE to enter (Setup) and configure.
Advice: Learn to use your calculator. The best way to achieve mastery is to look inside the manual whenever you do not understand something.
Dec 06, 2013 | Casio FX-300 Plus Scientific Calculator...
Somehow the y= option on my calculator has turned into r= and the x key is showing a zero with a line through it. How do I get it back to x and y ?
Press MODE to bring up the mode editor. On the fourth line, highlight "FUNC". Press ENTER to save the change and 2ND [QUIT] to exit the mode editor.
Dec 02, 2010 | Texas Instruments TI-84 Plus Silver...
I purchased a casio fx-115 ES calcullator. When I use it to calculate total resistance of a parrallel circuit, I use the formula: 1 over the sum of the reciprical of resistances in the circuit. When I...
There seems to be two completely different issues here.
By default the calculator will try to show a symbolic result. 1 divided by 120 is 1 over 120, after all. If you don't want to see fractions at all, press SHIFT MODE 2 to switch to the LineIO mode.
The other is the display mode. 1/120 is about 0.0083. Again, by default, the calculator automatically switches to scientific notation for numbers whose magnitude is less than .01, so it shows the number as 8.3x10-3. To change this, you have two choices. Press SHIFT MODE 6 to select the fixed decimal mode, and the calculator will prompt for the number of digits to the right of the decimal. Alternatively, press SHIFT MODE 8 2 to select the Norm2 mode. This won't switch to scientific notation until the magnitude of the number drops below 10-9.
Calculators only have two choices when a number gets close to zero. It can either round it off to zero, or switch to scientific notation. It doesn't matter how many digits the calculator can display, at some point it has to make the choice.
Nov 30, 2010 | Casio FX-115ES Scientific Calculator
Need to reset display on a casio 115es so only the zero shows up.
Press [SHIFT][MODE] to access (SETUP). Select [6:Fix]. then enter a number between 0 and 9. That will determine how many decimal digits the display will show. Entering 2 or 3 seems reasonable.
Dec 18, 2009 | Casio FX-115ES Scientific Calculator
Tonight my calculated started ending each answer in zeroes. I never have had this before. What is wrong?
First of all,what kind of calculator do you have? I suspect you inadvertantly changed the floating decimal point to a fixed one. That would give lots of zeros. Look at your calculator and find mode. It should be set on floating point.
Dec 01, 2009 | Canon P1-DHV Calculator
My calculater show 3 zeros all the time, how I can fix that?
The presence of the zeros is not a bad thing in itself. It depends on their positions (think of a bank account!) Although I cannot guess why the calculator would display 3 zeros all the time, I will try to help you Fix the number of DECIMAL digits to the standard 2.
Press [f] followed by 2.
Hope it helps.
Oct 31, 2009 | HP 12c Calculator
I have done something so the calculator is only displaying whole numbers and will not show anything after the decimal point. Thanks!
Hello
The floating point number display (FIX) is set to zero decimal digits. All your. numbers with decimal parts are rounded.
Look for a key that says [FIX]. Press it and enter a number say3 If I guessed right (Sharp makes numerous calculators) your numbers will show 3 decimal digits.
If there is no such key look for a [MODE] Button. Press the button. If you have a new screen with differents choices look for Format, Float,
On some older calculators there is a table below the display. At the left of the table one finds MODE--> or -->MODE
If it says there Mode DEG:4 that means to have angles in degrees you enter [MODE][4].
I think I exhausted all possibilities. Without you model number, I cannot do more.
Hope it helps.
Sep 04, 2009 | Sharp Office Equipment & Supplies
I have too many zeros after the decimal point and I need to delete them. How do I do that?
If got to do with the mode settings. Usually MODE fix in other lower version of calculator. The combination can be MODE FIX 0 for no trailing zero's if MODE FIX ONE then if will 0.0 or one zero then shifting the settings to NORMAL mode and at DEG mode.
Jun 26, 2009 | Casio FX-115ES Scientific Calculator
Using Cos/Sin
Calculator turns on in "degree" mode. Just enter angle in degrees then press "SIN", "COS" "TAN".
Most people work in degrees but you can switch to Rads or Grads to Degrees modes by pressing "DRG" repeatedly with zero displayed, Current angular mode will show in display.
Get a new instruction booklet by download from TI website
Oct 24, 2008 | Texas Instruments TI-30XA Calculator
Sharp el-531x scientific calculator Logo
218 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
