Question about RCA Audio Players & Recorders
How to we change the time to regular time on Model DLCR612U
How do we change the time to regular time?
Rca led tv shows military time is there a way to change it to regular time?
Having the same damn problem it's not in the settings menu or I would have changed it would need to know how to change this to regular time it's very annoying
Feb 20, 2014 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
When does the timing belt need to be replaced?, I have 99,343 miles
This model does not have a valve / cam / timing belt, it uses a timing chain, and they should last the life of the engine. No maintenance required, other than regular oil changes.
Aug 22, 2010 | 2003 Ford Explorer
2002 Grand Am GT transmission problem.
Well, there could be several possible problems. It is not uncommon to have a little harder shifting after a fluid change for a period if the system was low prior to the change however, If you had the fluid changed using one of those reverse flush machines I see the problem getting worse. Most stations want to use the back flush system to do a fluid change now days. That is because the newer model vehicle have a metal filter screen which is re-usable and is designed at the factory to use Synthetic Fluid. In the older model vehicles, 2000 to 2005, manufacturers where still mixing the types of filters that were being used. This model has a standard filter that model uses the newer filter. If you went to Jiffy Lube and didn't specify you wanted a regular Fluid and Filter change they hooked it to the machine and charged $140+ for the job. A regular Filter and fluid change with regular fluid would have run about $50. Every time, and I mean Every time, I have had a fluid change using that back flush machine on a vehicle within 6 months I have had to have the Transmission repaired at a shop. If you didn't have the fluid changed using that backflush machine then your problem is just adjustment to the new fluid being at the proper level. If you did, start saving for a Transmission rebuild at a shop, it's not far away.
Jul 19, 2010 | 2002 Pontiac Grand Am
When should you change timing chain?
timing chains are not serviced unless the engine is overhauled or the chain breaks, timing belts are replaced on a regular basis, this varies from 60,000-105,000 miles depending on brand and model, u have a chain.
Jul 17, 2010 | 1995 Nissan Maxima
I have the 444100 model and for somw reason i see
to change the clock from 24 hour time to regular am, pm time, all you have to do is press and hold the "up" button. it should change back to regular 12 hour time.
Oct 29, 2009 | Equity Time USA Sky Scan 44100 Clock Radio
I have a 97 toyota corolla and its running hot, does this model have a thermastat that needs changing at a regular time?
Changing thermostats really isn't a regular service but certainly needs to be done sometimes. The spring can get stiff. Try changing it first as that is the cheapest and easiest fix. If not that, there are several things it could be, first and formost though the water pump.
Jun 28, 2009 | 1998 Toyota Corolla
I have a built-in GE electric convection-regular oven. Model JT915W0F8WW. I don't understand when I push the convection baking do I change the baking time? Isn't it suppose to bake faster than the...
As a genaral rule of thumb.. Most recipes can be adjusted for convection oven use by decreasing the temperature by 25 degrees F and decreasing cooking time about 25%. Dishes with cooking times over 45 minutes, and that might dry out too much (like lasagna, or meatloaf) you should cover for the first half of the cooking time, and then remove the cover.
Aug 31, 2008 | GE Kitchen Ranges
Daylight Savings Times Changed
We set the time zone to '7' , which is Hawaii time zone where there is no change for daylight savings. This came up because it changed automatically on this morning...and although we can change it back, then it won't change next week when it should. So we're hoping that by setting it to Hawaii it will be a regular clock, we will do the changing...but at least we won't be surprized as we were this AM.
lb
Mar 09, 2008 | Emerson SmartSet CKS1850 Clock Radio
26 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
