Question about Casio Office Equipment & Supplies
Cassio 003 keypad reset
How to hard reset my cassio 003 exelim using keypad
Several keyboards with same prob. Willnot power up.Adaptor ok.Any suggestions or other issues to look for cassio 691 and 611
Power input sockets come away from the pcboard. Is the polarity of the power supply correct.
Nov 25, 2016 | Computers & Internet
Error code on toshiba laptop F3-f100-003
No doubt that the hard drive has serious problem, You need to replace the hard drive ... Then reinstall the operating system on the new drive using the disc you have.
Jul 31, 2014 | Toshiba Satellite Computers & Internet
Error code 003
"when powered on ,m/c displays 003 error code how do i reset it"
Feb 21, 2014 | Muratec Mfx-1950
I need a list of erro codes and definations for xerox workcentre 7232 serie. and I want the solution to my xerox workcentre 7232 copier. when switched on it shows erro 093-311
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Jan 16, 2011 | Xerox Office Equipment & Supplies
Ir3100 : E00070-003 error code
canon ir 3100 error code E00070-003
Oct 23, 2009 | Canon imageRUNNER C3200 Copier
How to get stock report from cassio TK-6500
For PLU stock balance report
1. Key turn to "X1"
2. Press [6][4] [CA/Amt Tend]
For PLU sold report
1. Key turn to "X1"
2. Press [1][4] [CA/Amt Tend]
Jul 24, 2009 | Casio Parts Cash Register PC Desktop
Codigo 602-003
Sorry, I only speak English. Error 602-003. Your hard drive is either dead or about to be dead. Call a technician to replace the hdd and reload system software using sst.
Jul 16, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Poor cassio watch display
You don't say how old the watch is and whether it has always had a display problem. I have seen several watches with weak displays, but generally they are older watches and I suspect the problem involves a corroded contact somewhere in the "movement". You might want to visit the Casio website and download a copy of the manual for your watch. It may say something about the display. If you watchis fairly new it may still be under warranty and again, contact Casio to see what you need to do.
Jun 13, 2009 | Casio G3011 Duplex LCD Watch
C500 internal keypad
If your keypad does not respond after power on, and Home screen looks normal, and NO keys respond, then it is likely not a key problem. It may be a software problem.
You can try a Hard Reset of your phone. See my previous C500 problem responses as to how to Reset your phone.
If you are half-way handy, you might try looking for an obvious hardware problem by disassembling phone to point of keypad cable-to-printed circuit board interface. Clean interface and unplug/replug cable. If this works, it will save you from losing your personal data and app files due to a Hard Reset of the software.
Jan 10, 2009 | Orange SPV C500 Pocket PC
12 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
