Question about Motorola Cell Phones
Unexperienced-need instructions on use
No instructions on use
    Top Expert:
  • Motorola Master
  • 14,161 Answers
OF COURSE YOU POSTED THIS QUESTION 10 MONTHS AGO AND ALL OF A SUDDEN IT POPS UP. WHAT A CHEAP SHOT FOR SELF PROMOTION. OK Anonymous, here is a suggestion, if you have not figure it out AFTER 10 MONTHS of use your not going to. READ THE MANUAL. OR GO TO http://www.motorola.com/support FOR SUPPORT.
Posted on Jan 31, 2015
  • Official Brand Answer
  • 3,100 Answers
My tv has suddenly gone dead checked plug etc no light or anything
Check the power supply regulator section for fault. If you are not handy, contact any experienced service technician. Handling power supply board and repairing it will be fatal to an unexperienced one.
Jun 08, 2012 | Televison & Video
Tip
Great fix! 4 infant socks, 1 adult sock, 2 collar stays, 1 finishing nail and...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F02” error code.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Nov 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tip
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Nov 24, 2009 | Kenmore Elite 45986 Front Load Washer
I need to check my fuel filter on my 1994 Mitsubishi Galant VR4. Where is it located and whats the easiest way for an unexperienced person?
For 1994 Mitsubishi Galant 2.4L MFI 4cyl the Fuel Filter is located under hood, driver side, upper firewall, mounted in fuel line.
Hope helps.
Apr 14, 2011 | Mitsubishi Galant Cars & Trucks
I have a sony projector and after my unexperienced stepmother used it it will not turn on. The light seems to come on and off and the lamp/ cover light is blinking. What did she do and how can i fix it?
The internal Lamp needs to be replaced. If you have the manual, look at the troubleshooting guide for LED flashing. Count the flashes, it will confirm or tell you of another problem. If you do not have the manual go to www.sonystyle.com and then support, enter your model # and you can download the manual. Once you've done this, google the model # of your TV add lamp and search shopping. You should be able to find it for around 100 to 150. It's very easy to replace and gives you instructions in the manual how to do it. Hope this helps.
Sep 19, 2010 | Sony Televison & Video
Is it hard to change a head gasket on a 03 dodge durango and do you know how i can find the instructions to do it?
It all depends on what type of engine you have. So get back to me and let me know that way i'm not explaining it a bunch of different ways to u. However head gaskets are pretty difficult, and are not for the unexperienced or the unmechanically inclined. You can find detailed instructions for these type of things in either a Chilton or a Haynes repair manuals.
Jul 11, 2010 | 2003 Dodge Durango
On a Jetta III 1994 give me the location of the fuel filter?
Its right under the rear seat on the pasanger side, need to unscrew 2 screws so you can lower it with the arness, then remove fuel lines, really easy a,so for unexperienced rooky
May 19, 2010 | 1993 Volkswagen Jetta
Timing belt repair
you can but it is very very complicated and lots of things to worry about. if you are unexperienced i would highly recommend bringing it to your qualified mechanic.
Jan 01, 2010 | 2006 Fiat Strada
We have a Whirlpool dryer. The strip of sealant is peeling off the inside back of the dryer. Does it need to be replaced, and if yes, how.
yes or else you may rust stains or torn clothing ..remove dryer front and pull tub out cut seal off and install new seal may a task not for the weak of heart can be a dog for unexperienced
Jun 01, 2008 | Whirlpool Dryers
Stereo Problem
This unit needs to be dis-assembled and the CD loading mechanism rebuilt. While a relatively straight-forward repair, this is not something to be attempted by an unexperienced individual. There should be no parts required for this repair, just the local labor rate.
Dan
May 22, 2008 | RCA RS2650 Shelf System
Cell Phones Logo
48 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Trisha
Trisha
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
