Question about Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC
Program will not open microsoft message appears
The ctrl+O keys don't work on photo shop and other programs. same with ctrl+T(or N) keys I am using microsoft wireless keyboard 700 v.2 the problem appears from the time I started to use this...
may be you should reset photoshop parameters, to do this follow these instructions :
1- Open photoshop, and juste when the Splach screen appears, press CTRL+ALT+SHFIT.
2- A message saying that photoshop is going to reset all parameters.
3- Confirm on that message.
4- Enjoy.
Good Luck.
Mar 13, 2011 | Computers & Internet
Installed software and plugged in Microsoft Lifecam VX-1000 webcam,but when I try to open program,message appears...."LifeCam.exe has encountered a problem and has to close. Please help
There is some problem with your operating system or Webcam driver. You just restore your windows and then install the driver.
  • 1st Click on Start.
  • Click on All Programs
  • Then click on Accessories
  • Click on System tools Then
  • Click on System Restore.
  • System Restore window appears
  • Then check this option
  • Restore my computer to an earlier time.
  • Click on next
  • Click on date where you want to restore your system then click on next.
  • And the Restore wizard will start.
  • After sometime the computer will restart.
  • After this hope your problem will solve.
  • Microsoft Webcam Driver
Mar 14, 2010 | Microsoft LifeCam VX-1000 Webcam
It says office application version does not match every time I open my documents.
Firstly
When opening a Microsoft Office program or file you may get a message that says “Office Application Version Does Not Match Error”. This is most likely caused by having the Outlook 2007 Business Contact Manager installed on your computer. Many computers that come with the Office trial program installed will have this on their computer from when it was new.
There are a couple of ways to get rid of this error. First you can install the update from Microsoft that gets rid of the error.
Or you can go into Add and Remove Programs (XP) or Programs and Features (Vista) and uninstall the Outlook 2007 Business Contact Manager if you don ’t use it. It won’t affect any of your Office programs. You may get a message during the uninstall process that it can’t remove it from your Outlook profile but just click Ok and finish the uninstall.
or
Bit of an odd one this error message. It is issued when you start Microsoft Word 2007 (or indeed Excel 2007, PowerPoint 2007 or Publisher 2007) on a computer that has Microsoft Office Outlook 2007 with Business Contact Manager installed. You can download a a patch that will stop this error message appearing here.
Hope this will solve your problem
Please rate this and vote
Feb 20, 2010 | Microsoft Office Professional 2007 Full...
How to run digital fortran 6 on windows vista
Here is what I did. Open the DVD (right click and select Open), and then open the X86 folder. Run the Setup.exe file from there and it should install and work fine. I had an error during install near the end, but it seems to have done no harm. I compiled one of my old Fortran apps and it works fine.
Dec 15, 2009 | Compaq Digital Visual Fortran Professional...
When I try to open a word doc. or excel document there is an error message and microsoft will not open them. but i can open the document through word or excel, by using the open feature. but just by double...
you have to right click the file (word doc. or excel doc.) and select "open with". A window will appear that allows you to choose which program will open this file. Select word for the word docs and excel for the spreadsheets and select the option to always do this for these files types. Once the default program has been set all other files with those extensions will now open with those programs. Good Luck and Please Respond to this post!!!!!1 Rate Fixya if the problem was solved!!!!! :D
Oct 06, 2009 | Microsoft Office Professional 2007 Full...
Microsoft visual basic message compile error in
It seems as if Microsoft has a knowledge base entry concerning this issue, see if this helps --> http://support.microsoft.com/kb/307410
It appears as if the problem is within the startup folder, which is located in C:\Program Files\Microsoft Office\OFFICE11\Startup ( NOTE: if you have Office 2007 then it would be in OFFICE12, Office 2003 = OFFICE11, 2002 = OFFICE10). Check out the above link for more specifics.
Hope that this helps....
Serge C.
Apr 09, 2009 | Microsoft Office Professional 2007...
Can't open ms outlook 2007
just restore your system and see
Feb 19, 2009 | Microsoft Computers & Internet
Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC Logo
Top Avanquest Computers & Internet Experts
Joseph Hoffmann
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
