Question about GE Ovens
Size of a jkp62g0k3
I just need the dimentions
Neff u1421 double oven , both ovens work fine but the grill trips the circuit breaker after 5 minutes of getting hot
you need to check size of breaker the oven is wired too if this is to small it will trip also cable size
Sep 18, 2013 | Neff U1421 Double circotherm Electric Oven
Jrp24bod1bb GE Double Oven
you would need a minimum of 48&1/8" high,23&1/2" Deep, and 22&1/2" wide and 14" off the floor for ventilation per G.E quick specs
Feb 18, 2013 | GE JRP24 Electric Double Oven
I purchased a Kenmore slide in range #4678 (Whirlpool) yesterday and have been unable to get the necessary dimensions to give to my installers. Can you help?
Try www.kenmore.com it shows this model but the dimentions on show 30 inches ask a question is thay have contact us,
hope this is helpful
John
May 19, 2011 | Ovens
What size wire do I need for a ge profile 27"
Well, 6800W/240V = 28.33 amps, call it 30. Minimum AWG wire size 10ga., if you're running it over about 20' go up to a 8ga. to be sure your oven is fed adequately.
lp
Jan 01, 2011 | GE Ovens
Tbf-610 outer oven door shattered how do i fix it
unless you have a spre from the dealer, then simply measure the fitting dimentions and don forget the thicknes. Then go toyour local glass dealer and ask for same size of glass but make sure its toughened glass and its high temparature tolerant. You can use the same ruber gascket or if not you can buy High temparature silicon silant to fit it back
Aug 06, 2010 | Ovens
Need to verify/reset oven size on a Whirlpool 307PVS double oven.
Found the electronics package manual on another web site and downloaded it.
Dec 13, 2008 | Whirlpool GBD307PRS Stainless Steel...
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Ovens Logo
81 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
