Question about SAMTRON 55V 15" CRT Monitor
Open cover of Samsung Samtron monitor
I have a Samsung Samtron monitor and these days its intermittent operation is bothering me. I know that the problem is loose power switch of monitor. When I turn one side the monitor turns ON and other side OFF. Now it is totally dead. Need some help in opening the cover so that I can replace the switch or bypass it.
Regards,
Indra
[email protected]
  • 1 more comment
  • indraseng Nov 14, 2007
    Thank you shaami.. i downloaded a manual for the monitor. anyway thanks..
    Regards,
    Indra
    [email protected]
  • varanasisai Aug 10, 2008
    i want to open the cover
  • rajeeshrnair May 11, 2010
    I removed those screws but after that, I could not make up the rest. The case on top do not get loosened nor released even after pushing it down using screwdriver. Any idea?
Remove two screws on lowerback of the monitor. Loosen the case at the botton and on the top. Two holes will appear on the top. With thin screwdriver push down inserting the screwdriver into this notch.This will release the case. Tks
Posted on Nov 13, 2007
IT works :D thanx dude, i didnt expect i will get solution in two googles :D
thank you
Posted on Aug 26, 2008
    New Friend:
Yes that is the point. I Got it solved
Posted on Jan 05, 2010
    New Friend:
NO OUTPUT FROM POWERSUPPLY
Posted on Sep 14, 2010
SOURCE:
I have samsung syncMaster 551s CRT monitor. i want to open its back cover. i found only two scrow and i have remove them. but now problem is i cant remove it. plz help me.
You have to find 2 holes at the top of the plastic cover (at the front edge of the back cover) of this monitor and place a flat blade screwdriver in them and gently press to unlock the cover.
Sep 22, 2010 | SAMTRON 55V 15" CRT Monitor
I can't open Monitor
there will be 2 plastic lugs on the top of the monitor. using a flat blade screwdriver you can undo these
May 12, 2010 | SAMTRON 55V 15" CRT Monitor
Removing back cover of samsung monitor 15'' crt 55v
I need some solutions to remove back cover for the CRT samsung monitor
Jan 17, 2009 | SAMTRON 55V 15" CRT Monitor
Cleaning inside of monitor
i never heard of cleaning a moniters internals. but yeah go ahead. use a artist medium paint brush and compressed air. watch out for compassitor it will still have a live charge even if unplugged.
Feb 03, 2008 | SAMTRON 55V 15" CRT Monitor
HOW TO OPEN COVER OF OVERSIDE?
first remove back side lock then take small pin like tuser insert into small hole & Push it up side it will open
Nov 14, 2007 | SAMTRON 55V 15" CRT Monitor
Monitor
SIGNAL CABLE WIREING.
1) RED
2)GREEN
3)BLUE
4)GROUND
5)BLACK SHIELD
6)BLACK SHIELD
7)BLACK SHIELD
8)BLACK SHIELD
9)BLACK
10)VILET
11)
12)ORANGE
13)SHIELD
14)YELOW
15)WHITE
Problem with opening monitor cover
to remove the back cover of samtron 56 v monitor is very simple.
locate the 2 bottom screws of the cover, remove them. pull slightly back the cover holding the bottom and about half an inch gap will be seen. insert a flat screw driver straight down through the upper side hole with your left hand and hit the head of the screw driver with your right hand. a slightly big sound is heard and that side is disengaed. repeat he same with the second hole. and you have done it. try.
Oct 10, 2007 | SAMTRON 55V 15" CRT Monitor
Intermittent Display
if you have the skill for take off the cover,take off the metal shield and cables until you reach the board,have a 100watt light on,a solder hot iron in one hand and a few rings of tin in the other, obviously take off the plug and left it over a few meters,and waited a few minutes to give some capacitors discharge time,.............it's easy !!! resolder the joints that like dark,mainly see the big transistors,(or IC)that have like rings on it's pins, and thats all. I tell you its easy okay then you have to "rebuild" your monitor back.don't make shorts pleeease.
Oct 22, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
3,143 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Ekse
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
