Question about Carl 12215 CUI-12215 Bidex Professional Rotary Trimmer
The mechanism that houses the rotary blade will not move
The mechanism that houses the rotary blade is stuck at the bottom of the paper cutter and will not move.
Need to sharpen the rotary blade
Top 5 Ways to Sharpen a Rotary Cutter Blade ' eBay
www.ebay.com > ... > Quilting > Quilting Tools & Equipment
Since the 1970s, rotary cutters have provided a reliable and efficient method for quilters, garment-makers, and other workers of fabric to create symmetrical and ...
Sharpening and Maintaining Your Rotary Blade from Scrap ...
? 5:54
https://www.youtube.com/watch?v=Kdd3JiWnmtE
Mar 13, 2012 - Uploaded by Craftsy
Sharpening and Maintaining Your Rotary Blade from Scrap Quilting with ... My online Craftsy class, Scrap Quilting: Waste Not, Want Not, will ...
Penny's Hands: How to Sharpen Your Rotary Cutter Blade
pennyshands.blogspot.com/.../how-to-sharpen-your-rotary-cutter-blade....
Mar 5, 2011 - And what has the aluminium foil to do with sharpening rotary cutter ...Thanks for that tip Penny, I have lots of blunt blades I can sharpen now.
Jan 27, 2016 | Food Processors
The cutter on my White super lock 1934D has dropped down and won't stay in the correct position to cut. How do I fix this?
The cutter mechanism connects to the machine whet the front is closed. If you look at the machine with the door open. You will see a finger coming out of the inside of the machine. If you turn the hand wheel it should move up and down. On the cutter mechanism there is a fork that fits over the finger. When it is all closed up it sould work together to move the cutter blade up an down. Is the cutter in the up position?
Apr 29, 2015 | Sewing Machines
Removing cutter
Is this a guillotine style cutter or a rotary style cutter? What brand/model? Some rotary cutters are self sharpening and some cannot be sharpened.
Jul 12, 2014 | Tools & Hardware - Others
What is a rotary paper cutter?
This is a cutter with a wheel-like blade that comes on a rail you can slide along. This lets you make cuts that are wavy or perforations. These are usually used at home becuase they are safer as the blade is wheel-like and not like a knife.
Jan 17, 2013 | Office Equipment & Supplies
Instructions for how to replace the rotary cutter blade in fiskars rotary cutter, searched online but, not getting what I'm looking for... where does the washer go in placement...
I am trying to get something from Fiskarcrafts.com on the rotary cutter that you have. I will let you know when and if I get something. Also you might check out their website, sometimes they have online help.
Sep 21, 2009 | Fiskars Brands Donna Dewberry Rotary...
Rotary cutter shakes
If a roc bent the pan - I dont see how that would make it shake..
I suspect the shaft..
Hoe this helps !!
Jul 14, 2009 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Mar 18, 2009 | Simplicity Serge Pro SW432 Mechanical...
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
UP-DR100 Error 0008 problem
Problem: The Printer does not detect the Reverse position of the cutter during initialization.
Either there is a scrap piece of paper obstructing the path of the carriage that houses the cutter blade or more than likely impact on the lower left side of the printer causing a bend in the metal that holds the Reverse switch.
This switch will trigger a sensor telling the printer that the cutter has reached the Reverse position(left side)
The grinding noise is caused by the cutter carriage rubbing on the inner side of the door panel. The door panel shifted inward and is obstructing the path of the cutter blade.
Solution:Replace the door panel and check for damage on the left side of the cutter blade path and bend the metal piece to realign the switch so that the plastic carriage makes contact when reaching the left side. Or replace the whole cutter blade assembly.
Any replacement parts can be ordered from imagingspectrum.com.
Jan 30, 2008 | Sony UP DR100 Thermal Photo Printer
Carl 12215 CUI-12215 Bidex Professional Rotary Trimmer Logo
210 people viewed this question
Top Carl Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Carl Office Equipment and Supply Expert? Answer questions, earn points and help others
