Question about Acer Aspire Computers & Internet
Wont power on
Turns on then shuts off after 5 seconds
    Top Expert:
  • Acer Master
  • 8,063 Answers
Check that your fan is running could be over heating,if so clean the fan.
Posted on Apr 05, 2015
Mid tablet wont shut down
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Jan 30, 2013 | mid Archos M729B Android Tablet
Screen asks if you want to reboot etc. but wont reboot
Press and hold the power button until it shuts off (should take 4-5 seconds). Then turn it back on :
or, remove the power cable and the battery. This will shut it off. Then restart with battery back on.
Get back to me if you have any problems with it....
Hope this helps!
Joe
Jan 03, 2011 | Acer Aspire 5920-6727 Notebook
I clicked reboot not my iphone wont turn back on what do i do????
Iphone Connect With Itune
Turn Off Your Phone
Press Home Button for 5 Second
After 5 Second Press Power Button for few second
Release Power Button
Still Holding The Home Button
Itune Detect Your Iphone In D.f.u Mode
Release Home Button.
Jan 20, 2010 | Apple iPhone Smartphone
My hp notebook just shut off,wont come back on
Sounds like a burnt out capacitor. Either on motherboard or power supply.
You can try taking out battery, press and hold power button for 5 seconds, put back in and try to turn on. If it doesn't turn on, then I'm afraid motherboard is bad or memory card is faulty
Nov 11, 2009 | HP Pavilion dv2610us Notebook
DC 17 UPRIGHT BRUSH MOTOR WONT STAY RUNNING. TURN
have a look at the filters first as it sounds like you blokeage
Oct 31, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Laptop shuts down in 6 seconds.
Most proably it is a main board problem. Contact authorized service center.
Jan 27, 2009 | Gateway MX6448 Notebook
I have a 95 Maxima I changed the fuel injectors and now the car wont start.  so i put the old injectors back and it still wont turn over,  It stay on for about 2 sec can anyone help me
I assume you bled off fuel pressure before you installed the injectors. Try this to pressurize the fuel system. Turn the key to "on" position and wait 5 seconds. AT same time, listen carefully for a buzz sound that means the fuel pump is running to pressurize the system. It will shut off after 5 seconds. Then, turn off the key and wait 30 seconds for the computer power relay to shut off. Then, turn the key to "on" again. Thsi will run the fuel pump for another 5 seconds. Repeat 5 times. Fuel system should be pressurized now.
If it doesn't start now, you may have done something while you were changing the injector. good luck
Jan 09, 2009 | 1987 Ford Tempo
Flashing yellow
Good Day, davidsonkens;
Try the lamp first; to check try this:
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH. back.gif
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
