Question about CDA WC430 Dishwasher
Flashing lights and beeps 10 times
When turning on machine, on 4 lights start flashing and beeps 10 times, i have a cda wc430
I an you explain what symbols are eg glass / spray etc and time and temperature of each symbol
http://kitchen.manualsonline.com/manuals/mfg/cda_kitchen_appliance_manufacturer/wc430.html
Jul 06, 2015 | CDA WC430 Dishwasher
I have the CW447 integrated dishwasher which won't fill with water
Like most electrical appliances what worked for me was turn it off at the wall for 10 mins, then turn it back on. Did you get an error code? Check the pipes are not twisted and that the water supply is turned on full. Let me know how you get on
Apr 13, 2014 | CDA WC430 Dishwasher
It starts the cycle then it drains down and the bleeping starts saying theres a fault.
MAY BE A LEAK AND ITS ACTIVATING FLOOD SWITCH WHICH WIL DRAIN MACHINE TO STOP FURTHER LEAKS CHECK SEALS AND MOTOR SEALS FOR LEAKS
Jun 17, 2012 | CDA WC430 Dishwasher
Cda wc140in
Hello, hope you can help? I brought a second hand (but brand new, but not used CDA wc140. Its plumbed in fine, switch on, the end light comes on, the programme button just beeps when pressed. There's no info in the manual. I hope I haven't brought a second hand dud, any ideas to start would be greatly appreciated. Steve...
Apr 24, 2012 | Dishwashers
The CDA WC360 dish washer is no longer effective. It appears that the solution, whether in tablet or liquid form is not leaving the dispenser. Can you please advise?
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
May 05, 2011 | CDA WC430 Dishwasher
I have a cda mx194 dishwasher 1st three lights are flashing and it is beeping it wont start the cycle
MX194 Dishwasher.
Switch off and unplug before doing anything. .
First three lights are flashing on top and it will not stop making stupid noises.
Remove plastic panels at front of machine under door, see if there is water inside.
If there is ... something is leaking. If it is a slow leak - solution is to dry up excess water in tray with paper towels or whatever comes to hand. You will need to find the leak somehow - salt container is usual suspect.
There is a microswitch attached to a float on the left hand side inside a white plastic cover. Water at the base of this activates the switch and disables machine. Mine has not leaked since trying this fix and machine is running well 2 months down the line. Better 10 minutes with paper towels than 2 hours of expensive plumbers.
Jun 15, 2008 | Dishwashers
Cda dishwasher
green light on right flashing and beeping noise..Problem solved by thowing a few pints of water in the bottom of the dishwasher...must have 'primed' the pump..which must have been the problem; working fine now. David- Crosby
Apr 19, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
May 19, 2007 | Zanussi FJS1225W Front Load Washer
CDA WC430 Dishwasher Logo
Top CDA Dishwashers Experts
David Payne
David Payne
john cordey
john cordey
Are you a CDA Dishwasher Expert? Answer questions, earn points and help others
