Question about Rule 1800 H53SP-24 Swimming Pool Cover Pump
Will not run
Just stop working while on cover
What cause my 2000 dodge neon to stop on me and now it wont even turn over. and all of the spark plugs is cover in oil?
it is possible that your neg battery terminal could be losing contact or coil could have stopped working and im sure the oil on the spark plugs has a bit to do with the running issue . You need to change the valve cover gasket make sure nothing is cracked clean up the valve cover and engine side surface install valve cover gaskets and bolts torque em down and see what happens youll probably have to replace the spark plugs or clean them up real good
Jan 26, 2015 | 2000 Dodge Neon
Will only run for 10 secs then stops, if throttle is opened when it runs, it stops immediately
Spark plug was dirty and covered with burnt oil.
I cleaned with steel brush. Worked like magic.
To avoid this, do not overfill oil above second mark
Dec 02, 2013 | Makita BHX2500 24.5 cc Blower
My electic chain saw works intermitently. motor goes, chain doesnt.
yes the gears can strip look at sears parts online for a break down
Mar 24, 2012 | Ryobi Garden
Instrument cluster not working but jeep runs fine
Often the whole instrument cluster runs off of the same fuse. Did it just recently stop working? If so, has there been any work done recently to the stereo or any of the dash controls?
A fuse blowing just because it's worn out, or old, is not very common. Most fuses are damaged from electrical work being done and someone accidently touches something that sends an electrical surge which blows the fuse.
You should be able to remove the fuse cover, inside the car on the driver's side. When you remove the cover most have a fuse diagram on the inside of the cover.
I hope this helps.
Jan 26, 2011 | 1998 Jeep Cherokee
Hi My Electrolux Oxygen Z5530 stopped working from one second to another. No lights - nothing - totally dead. What can I do? Is there any fuse? Sincerely Eva
I have same problem and I check it out.
The special requrement of Electrolux for his vacum cleaner motors is that they working with high reliably approx 800 hours working time and no more!!! (it should stop safe with no danger for users...)
7 years has past (2 h/week x 52 x 7 = 708 working hours) so it is time for us consumers to buy new vacum cleaner...
Jan 05, 2011 | Electrolux Vacuums
Engine has been running well- oil line to fuel pump fell off-repaired but now cant strat engine= no fuel to engine-okay off pump but maybe low pressure
Fuel cutoff was stuck in closed position and sticking.opened valve and engine started but stopped again as valve closed. Lubricated valve with transmission oil and now works okay. Valve is under a light metal cover on rear end of pump on top. removd cover & found problem.No oil or fuel under cover-can run engine with cover off Now working OK after lubricated with trans oil -thanks anyway
Nov 10, 2009 | Farmall IH Tractor 706, 756, 806, 856,...
Wipers do not work on 2005 toyota camry
Jean first thing to ask is do you hear a motor running / next if you hear a motor running then check the arms there are covers wherethe arms connect make sure they are tight/ then if not check the fuse box one is under the dash and the other is in your engine compartment lif the covers off and it will tell you exactly which one it is and replace that fuse
Jan 26, 2009 | 2003 Toyota Camry
1994 Ford Thunderbird Wipers Stopped
check the arms there is a cover under cover there is a bolt tighten it back up
Jan 25, 2009 | 1994 Ford Thunderbird
Rule 1800 H53SP-24 Swimming Pool Cover Pump Logo
77 people viewed this question
Top Rule Pool & Spa Experts
Bill Jordan
Robco Water
Robco Water
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
