Crystalview xt my tablet is brand new but when i turned it on, it would only boot as far as the android logo(robot), and then it just stays there not loading all the way. it looked like it was interrupted when they installed the os. what can i do to make this work?
    Master:
  • 425 Answers
You need to contact the manufacturer
Posted on Aug 18, 2014
2 Suggested Answers
thomashmorri
  • 16 Answers
SOURCE: crystalview android netbook troubleshoot ?
http://crystalviewtablet.com/uploads/TB4-4-5580_Manual.pdf Here is the manual and it looks like you can go through the settings and there should be an option to reset the unit.
Posted on Apr 28, 2014
I did a factory restore on my android crystalview xt and now it wont go pat the android logo screeen.
After reading reviews on this it appears to be a manufacture issue. If it has a reset button on the bottom. "one that you usually use a pen to hold down then power off and back on" that might be able to reset the o/s for you. personally i would contact the mfg through amazon and send it back for an exchange.
Mar 09, 2015 | CVS/Pharmacy CrystalView XT Android 2.3 7...
How Do I Reset an Idolian Studio 10 Tablet that is looping on the Android logo?
The robot dude meant it was loading up the system settings to the next screen so you can wipe off corrupted data that prevents the tablet from completing startup.usually an incomplete update.So
as follows ... Hold power button to switch off tablet....then hold power button and volume up together for at least ten seconds.let the robot appear and do nothing until the menu option comes up to ask you to factory restore.you will lose all your apps and data.if the robot comes on and gets stuck make sure the tablet is fully charged and repeat the two button hold as this may take several attempts.sometimes Chinese technology is unpredictable.
Jan 26, 2015 | Idolian 10.1" Android 4.1 Jelly Bean OS...
Crystalview xt
you need to reload your windows, cause it sounds like you have corrupt startup files, also check your hard drive for errors.
Mar 20, 2014 | Computers & Internet
When i turn on my tablet 4.0 the android logo comes on and stays on ,do i need a driver
See if there is a reset on it. Its usually a very small hole marked reset and it takes a pin or something very small to press it. A reset might work and it won't erase anything off it.
Jan 23, 2014 | MICHLEY TIVAX Michley MiTraveler 7 inch...
Crystalview xt manual
I cannot say for certain; however, several reasons cause this to happen. One is Old communication drivers need to be replaced with updated versions. Distance can be factor; how far from the source (Modem or WiFi sender) to the tablet? Then there is hardware factor> some internal Wi-Fi receivers inside of the tablets start to weaken over time and die completely sometime down the road. The final factor can be damage to the sensitive electronic parts and circuit board. If a tablet has been dropped or misused; the tiny and thin mainboard could fracture. Cold and/or heat could open a vital connection and if the board has a separation point, the opening (called a SHORT) will disconnect a portion of Audio, Video, or Communication sections. Your problem has a variety of possibilities which require actual inspection of the Tablet by a Technician.
Dec 22, 2013 | Computers & Internet
Lost charger for my my crystalveiw xt
it should say on the documentation that came with it
Dec 07, 2013 | CVS/Pharmacy CrystalView XT Android 2.3 7...
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
