Question about Generic gigaware 16-998 sdhc high-definition 1080p digital camcorder w/5x opti
Gigaware 1080p camcorder says no file when trying to look at pictures
It sounds like it is taking pictures, but when I try to view, it says no file. I put a full size 16GB sd card in and formatted several different times to try to get it to work. I used a micro sd with adapter fisrt, but had format problems and same message of no file when they did format.
Recover deleted videos from jvc everio gz-mg21EK camcorder hardrive
You can recover deleted videos from camcorder with video recovery software like asoftech data recovery. You may refer to this tutorial that helped me before
How to Recover Video Files from Camcorders
Feb 27, 2011 | JVC Everio GZ-MG21 Camcorder
No sound on transferred files
Please see and read the Software manual (link)
Yes you need to use provided software ie power dvd 5 ne
extract from page 12 software manual
Dec 31, 2007 | JVC 20GB Everio GSeries HDD Digital...
Tip
Upload/Share Videos to SmugMug-Convert Panasonic SD90 AVCHD MTS files to 1080p...
Compress/Shrink SD90 AVCHD MTS to MOV for SmugMug with Keep Highest Quality <br /><br />I have a Panasonic Camcorder, HDC- SD90, which produces .mts files with 1920*1080 28Mbps. I record some more mts videos by sd90 and want to upload to SmugMug for sharing with my friends. SmugMug does a great job with MTS video, it supports 1080p HD and can take an MTS file directly. The upload times for an MTS file shot in 1080p (28Mbps!) though are too long, so I need to compress 1080/28Mbps video before uploading .To solve the problems, I recommend a professional program named <b>Final Mate</b>. This professional Camcorder Software - Final Mate can <b><a href="http://panasonic-avchd-converter.com/2011/06/upload-panasonic-sd90-recording-avchd-mts-video-to-smugmug-shrink-avchd-footages-to-mov/">Convert/Shrink Panasonic AVCHD footages to MOV for Upload/Share Videos to SmugMug</a></b> with best quality. <br /><br />Below is the fast guide for you to <b>Convert and Compress AVCHD files from Panasonic HDC-SD90 Camcorder to .MOV Videos with Highest Quality for Uploading/Sharing to SmugMug</b> on Windows XP, Windows Vista and Windows 7. <br /><br />Step 1. Get <b>Panasonic HDC-SD90 1080/28Mbps AVCHD footage to Final Mate</b>. <br />If you have already backup all your mts video recordings from Panasonic SD90 to your computer, you can browse your video path via "Add" and the software will automatically show your AVCHD clips in Resource Tab. <br /><br />Step 2. <b>Create a Movie for Convert Panasonic SD90 MTS Files</b>. <br />For conveting Panasoni HDC-SD90 MTS files to mov and keep highest quality for uploading on SmugMug. First need to create a movie for conversion by selecting Add &gt; For Conversion in Movies Tab for putting mts video clips on. Then select all the files from the Resource tab using Ctrl+A, drag and drop to the movie in Movies tab. <br /><br />Step 3. Choose export format - <b>Panasonic HDC-SD90 MTS to MOV for SmugMug Pro</b>. <br />Click the Export button, and go to the Devices tab. Choose HD Video - H.264 HD Video(*.mov) for conversion . <br /><br />Step 4. <b>Set Video/Audio Quality and Export</b>. <br />To get high quality videos, you can choose 1920*1080 size(pix),frame rate 25fps,medium quality as video bitrate and 256K audio bitrate before starting conversion.The quality loss is not significant, the videos still look great when viewed. Click OK to start <b><a href="http://www.aunsoft.com/final-mate/">Converting Panasonic SD90 AVCHD MTS files to 1080p MOV for SmugMug</a></b>. <br /><br />When the Panasonic SD90 MTS Videos to 1080p MOV conversion is done, you can quickly <b><a href="http://www.aunsoft.com/final-mate/">Upload Panasonic SD90 Recording MTS Video to SmugMug</a></b>. I also keep the MTS files as a backup - these play OK locally in WMP and Popcorn Hour.
on Jun 15, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
AVCHD merging software-Join AVCHD MTS Videos for Playing on Plasma TV without...
Lossless Join/Merge Sony AVCHD MTS Videos to Play on 1080p Plasma TV <br /><br />If you have bought a Full 1080p Plasma TV, no matter Panasonic, Samsung , Vizio, Pioneer, or Sony, and got a Sony AVCHD camcorder like Sony HDR-TG5V, Sony HDR-TD10, Sony DSC-HX5V, Sony Alpha NEX-5, Sony NEX-VG10, Sony HDR-XR520V, Sony HDR-XR500V, etc with 1080p or 1080i AVCHD recording in 2011, you may like to connect your Sony Camcorder to Plasma TV for sharing precious videos at home, but before enjoying, you may like to join the related videos and create home movie for series. <br /><br />The windows version of PMB (Picture Motion Browser) for Sony camcorders doesn't work well, and there is rare satisfied <b><a href="http://sony-mts-converter.com/2011/06/lossless-joinmerge-sony-avchd-mts-videos-to-play-on-1080p-plasma-tv/">AVCHD merging software</a></b> on the market, after searched, I found a professional AVCHD Joiner, which can be used as <b><a href="http://www.aunsoft.com/final-mate/">Sony MTS Joiner for Plasma TV</a></b>. With only three steps, the videos could be combined into one single file, keeping the original 16:9 aspect ratio, video format, video codec, bitrate, etc for HD playback on Plasma TV. <br /><br />Now I will show you the quick guide to <b>join Sony AVCHD videos to play on 1080p HD Plasma TV</b>. <br /><br />Step 1. Load Sony videos to Aunsoft Final Mate. <br />Connect Sony camcorder to PC with USB 2.0 cable, or use a card reader. Run Aunsoft Final Mate on Windows XP/Vista or Windows 7. Follow camcorder wizard included in Final Mate to easily capture and download AVCHD files from camcorder to the program. Or you can click on Browser button to locate your AVCHD file path and Final Mate will automatically show all Sony AVCHD MTS/M2TS files in Resource Tab. <br /> <br />Step 2. <b><a href="http://www.aunsoft.com/final-mate/">Join AVCHD files into one movie for Plasma TV</a></b>. <br />Click the Add movie button, and a movie for lossless output will be created by default. Select the files you would like to join into one file from the Camcorder tab (imported from your camcorder) or Resource Tab (imported from your computer), drag and drop to the movie. <br /><br />Step 3. <b><a href="http://www.aunsoft.com/final-mate/">Lossless merging MTS for Plasma TV without re-encoding</a></b>. <br />Click the Export button. As there is no video for conversion, just click the OK button for lossless output. The lossless output will be finished in a few seconds or minutes. When the merging process is done, just put the videos to the Plasma HDTV SD memory card slot and enjoy the movie.
on Jun 07, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
My Gigaware HD 1080p 3" Touch screen Camera wont
Looks like your screen flat wire connector is loose and worse it is torn.Replace it.
Oct 27, 2010 | Haier D36FT 1080p HD Camcorder with 3Inch...
HAVE THE DVG-1080P CAMERA, THE AUDIO AND VIDEO DO NOT MATCH UP!. IVE TRIED USING IT IN SEVERAL QUALITY SETTININGS AND ALWAYS END UP WITH AUDIO THAT RUNS FASTER THAN THE VIDEO!
Are you playing the video from the memory card? What I've found is that sometimes the file isn't processed cleanly from the card, than if you'd drag and dropped the video file to your desktop...
Jun 08, 2010 | Polaroid DVG-1080P HD Camcorder
When i upload my videos from my polariod dvg-1080p onto my laptop, they come up as pictures. then when i try to watch them, they wont start
Question? I'm not trying to be rude at all, but did you actually take a video or did you possibly press the "photo" button by mistake? I know that I've done that a couple of times myself...it's entirely possible.
May 17, 2010 | Polaroid DVG-1080P HD Camcorder
I have an Aiptek 'Action HD 1080P'. I am trying
You cannot transfer or copy images recorded on one device to another - even if they are the same file type, the formats are incompatible.
Jul 20, 2017 | Aiptek DV4100M Camcorder
Generic gigaware 16-998 sdhc high-definition 1080p digital camcorder w/5x opti Logo
23 people viewed this question
Top Generic Televison & Video Experts
L Pfaff
L Pfaff
CoppellTVRepair.com
Are you a Generic Televison and Video Expert? Answer questions, earn points and help others
