Weather channel not working
Problem on my I Pad
Outdoor temperature does not display on indoor pad. They are less than 20 feet away.
There may be a channel selector on the units and you have to make sure they match.
Nov 26, 2016 | Measuring Tools & Sensors
The weather channels quit working on my cobra 29 nightwatch.
its an internal problem , take it to a tech and let them fix it. the board for the wx probably has jumped freq. and thats why you can't receive wx.
Apr 10, 2015 | Cobra 29 WX NW ST 40-Channels Base CB...
Cant get weather on my motorola MH370CR
Setting the Weather Channel
Your should radio receives weather frequencies if you are close enough to a reporting station:
1. After turning weather reception on, press . The current
Turning Weather Channel Reception On and Off
1. To turn weather reception on, press and hold + (plus) for three
seconds.
2. To turn off, press + or turn the radio off and then back on.
Your radio receives weather frequencies:
1. After turning weather reception on, press MENU . The current
channel flashes.
2. Press + or - to select the appropriate channel with good
reception in your area.
3. Press PTT to save the weather channel setting.
Here's a link to the MH user guide.
Best regards.
http://www.motorolasolutions.com/web/Business/Products/ConsumerTwo-WayRadios/Talkabout-MH230R-Two-Way-Radio/_Documents/MH230.pdf
Feb 02, 2014 | Motorola Radio Communications
Cobra CB 29wxnwst no weather?
I think you have a capacitor on the wx board thats been cut and / or removed.If it has been cut and its still in the radio all you have to do should be replace it. I think it # C608 ???
Jun 26, 2013 | Cobra 29 WX NW ST 40-Channels Base CB...
Which is better? The Weather Channel Vs AccuWeather for iPhone
While AccuWeather is better looking and has more of a Mac-feel to its interface, The Weather Channel app trumps it by offering more essential information in an easy-to-access manner. The Weather Channel is a free download in the iTunes App Store.
Sep 06, 2010 | iPhone Apps
I just aquired a Regency R 4010 portable scanner and am looking for the frequency range and programing instructions.
Turn scanner on.
Make sure Key Pad is set to ON.
Press the manual button until the Channel display shows the channel you want to program (i.e. 1 thr 10)
On the key pad enter the freqency and hit the E key when done.
Hit the Manual key to select the next Channel you want to program.
Repeat process.
When finished hit the scan button.
If you want to see what freqency is programmed for a channel hit the Manual button until you reach the desired channel then hit the Review button.
If you want to lockout a channel (i.e. a channel that continuously broadcasts like the National Weather Service, hit the Manual button until you reach the desired channel then hit the L/O button. Hitting it again will unlock the channel.
Jan 29, 2010 | Office Equipment & Supplies
Cobra 75 wx st everything seems to work eccept receiving signal meter will spike on trx and it seems to receive but no sound there is sound in wx mode
WX is for weather. If you put it on WX, and you do not hear anything, then you need to change the weather station it is on. in wx mode, you change weather channels by pressing channel up and down. To communicate with 2 way, press the cb/wx button so it is on CB mode.
Sep 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Twilli811@hotmail.com
check the SWR's on antenna. check microphone it has to work for the RX to be heard. cbshop
Sep 06, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Is the Weather Channel TV/Lantern/VEC130B digital?
I have the same TV as in the picture and it is analog(didn't check model #). I know of no way to use a converter box on it short of hacking it apart. Although it can still pick up any low power analog channels that maybe in your area. I just bought a nice hand cranked paperweight just a few years ago. lol
Nov 11, 2008 | Weather Channel COMPACT TV/LANTERN/ EA...
Televison & Video Logo
Top Televison & Video Experts
