Question about Exerpeutic 400XL Folding Semi Recumbent Bike with Pulse Sensors
Exerpeutic 400xl pedal
Pedals were making noise and not rotating smoothly. Next thing I knew one of the pedals fell off. What now?
Got a Brand new steering wheel and pedals from Thrustmaster T80 connected and the pedals don't respond!
This might sound silly, but its always the first thing to check; do you have the pedals cord plugged into the steering wheel console? Next, go to Start, Devices and Printers, and double click on your device. Try fiddling around with the different settings for the pedals and see if that brings them back online. I would check after each adjustment. Finally, make sure all your Thrustmaster drivers are installed, that the game you're trying to play has the pedals set up, and that all connections are tight. Hope this helps!
Jan 03, 2015 | Video Game Consoles & Games
Noise and rough pedaling from main crank
not knowing if this is a single speed or multispeed bike, this could be several different things and a proper analysis by a mechanic at your local bike shop is what is needed.
It could be that the chain is too tight, it could be the derailleurs are out of adjustment and the chain is skipping between gears or rubbing on the derailleurs. It could be a bottom bracket out of adjustment and the bearings are loose and making the noise. It could be a loose bottom bracket shell in an aluminum frame make creaking noises.
Aug 14, 2014 | Cycling
How fix singer foot control fuse broken lots little discs fell out of control
You didn't specify a model, but foot pedals are generally used by a wide variety of models of machines. Go to eBay and enter your machine's model number, and you'll probably see foot pedals for your model of machine for sale.
Aug 11, 2014 | Singer Sewing Machines
Pedal gear makes snapping noise
need new pedals, they screw off and one if left hand thread and one is right hand thread. or
unscrew both over the top to the rear.
Apr 11, 2014 | Tunturi E30 Ergonomic Exercise Bike
Machine is Quivering while excersisng
follow this steps and fix it. God bless you
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Lubrication
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
Nov 13, 2013 | Sole Fitness Sole E55 Elliptical
Next power climber
The bottom bracket on a bicycle connects the cranks (arms that the pedals are connected to) to the bicycle and allows the cranks to rotate freely.
It looks like this is worn out or broken. Any bike repair shop will replace it. Shouldn't cost much.
Jul 09, 2013 | Cycling
The pedal makes a clicking noise
If it's a fairly new pedal, I would remove them and try a different set of pedals to make sure that it definitely is the pedal. Assuming the different set doesn't click, then you may have a warranty issue. If the bike is still clicking, you may have to check the crank and bottom bracket next. The tough thing about clicking noises in the bottom bracket area is that there are a lot of parts that can be causing it and you just have to eliminate them one by one.
May 05, 2012 | Shimano PD-A530
Front crank sprocket clicking on bycycle, when I pedal the front crank sprocket clicks, it isn't the pedals.
make sure all sprocket bolts are tight.
check chain to make sure you have all rollers between links are there.this can make a clicking noise or skip teeth if one is missing when you pedal.
if you feel clicking in the pedals (even if you think it isnt the pedals),then it could be your bottom bracket bearing gone.
put one pedal towards the floor and stand on it.did it click?then try the other pedal.if you got it to click then your bottom bracket is loose
Sep 13, 2010 | Cycling
Makes Clicking Noise Pushing Pedals Down. Both Sides
Make sure the pedals is adjusted right.Then check if the pedals is not joking.If dosen`t work, change the clik in the back...tel me when it`s don:D
Aug 25, 2009 | Cycling
Proform XP110 R recumbent bike makes clanking noise.
I have the same problem with my XP 110. After taking the ENTIRE thing apart and independently testing every single moving mechanism, I found out that it wasn't the motor, pedals, armbars, or any internal mechanism. Instead, it was the front stabilizer foot that made the annoying noise. There is a plastic mechanism around the front stabilizer legs that holds the front wheels in place (for moving the elliptical). Whenever a rotation forward occurs, the plastic squeaks and the noise resonates to make it sound like the pedals or motor is squeaking. I am still trying to find a solution to fixing the feet, but may end up ordering a new set from the manufacturer. Good luck with your elliptical!
Mar 22, 2009 | Exercise & Fitness
Exerpeutic 400XL Folding Semi Recumbent Bike with Pulse Sensors Logo
44 people viewed this question
Top Exerpeutic Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exerpeutic Exercise and Fitnes Expert? Answer questions, earn points and help others
