Question about Dell OptiPlex GX520 PC Desktop
Computer will not turn on
Power is on but nothing on screen
My hp touchsmart310 PC will switch on but there is nothing on the screen ?
You can perform these steps even though the screen is blank.
  1. Turn off the computer, and then remove the power cord.
  2. With the power cord disconnected, press and hold the power button for five seconds.
  3. Reconnect the power cord, and then turn on the computer.
  4. Repeatedly press the F10 key about once every second for five seconds after turning the computer on.
  5. Wait five seconds.
  6. Press the F5 key. This restores the default settings of the BIOS.
  7. Press the Enter key. This accepts the changes.
  8. Press the F10 key. This opens the Save and Exit window.
  9. Press the Enter key. This saves the changes, exits the BIOS, and then the computer restarts.
  10. After the computer restarts, the screen should display the HP logo.
Hope it helps!
Aug 11, 2014 | HP Touch Smart Desktop Computer "brand...
Dell inspiron 630m laptop. turned it on, programmes started up then died. turn it on now nothing on screen but there is power. no fan running all the time or overheating. think it might be the video card...
> no power
> no fan running
Remove the battery.
Disconnect the AC power adapter.
Use a "multimeter" to test the voltage/amperage output from the adapter.
Connect the AC power-adapter, and try to turn the computer on.
If nothing happens, then the computer's motherboard has "died".
Take the computer to a qualified technician, for professional trouble-shooting.
Mar 15, 2011 | Computers & Internet
Nothing comes up on the screen when i turn the computer on, the power light is on but nothing shows up on the screen
Try pressing Fn + F2 key after turning the computer on. Try to perform power drain. Taka out the battery and unplug the adapter. Presss and hold the power button for 30secs. Put the battery back in and plug in your power adapter then turn on the computer.
Let me know if you will still be getting the same issue.
May 19, 2010 | Toshiba Qosmio G15-AV501/R Notebook
Turn on power,its stay on and off.screen wont open.see black screen only.
please perform power drain. take out the battery and unplugged the power adapater. press and hold the power button for 30secs. put the battery/power adapter back in and turn on the computer.
OR
once the computer is turned on. try presing Fn+F2 to enable LCD backlight .if nothing happens you may consult your manufacturer for LCD replacement
Apr 02, 2010 | Computers & Internet
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
My lab top when restarted it beats 3 times, screen blank
Nothing to worry, Open your laptop from the back side.Remove the RAM  and reinsert it.
Your system will work fine.
Rate this solution.
Dec 27, 2009 | HP Pavilion dv9700t Notebook PC
Power button just flashes will no turn off AND nothing on the screen
On back of the computer is a on off switch for the power supply, or unplug the computer for one minute. Turn the switch back on, or plug the computer back in and try to turn it on.
Apr 20, 2009 | Computers & Internet
Going to Sleep Displayed
I turned on my computer and the monitor displayed this message on the screen "going to sleep no input received". I checked the power cord and unplugged it, nothing. No lights are flashing or beeping sounds. The CPU is working just fine, anyone have any idea what to do
Aug 02, 2008 | HP vs19 (Silver) 19" LCD Monitor
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
Dell OptiPlex GX520 PC Desktop Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
