Question about Minolta bizhub 200 All-In-One Printer
HOW TO REMOVE THE PAPER TRAY
PAPER JAM. HOW TO REMOVE THE TRAY TO CLEAR JAM
  • Minolta Master
  • 6,680 Answers
To remove the paper tray draw 1 or2 or 3or 4 on the right side of the draw you should see a single screw it holds a small metal lock remove it and the slips all the way out.
Posted on Dec 30, 2014
How can I remove the paper input tray of a Topshot laserjet pro M275 to clear a paper jam?
Follow the directions here: http://support.hp.com/us-en/document/c02986019
Feb 23, 2015 | Office Equipment & Supplies
REMOVE PAPER TRAY TO CLEAR PAPER JAM
This may help. Only feed business card paper through the manual feed tray. Good luck.
Sep 10, 2012 | Dell 946 All-In-One InkJet Printer
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
How to clear paper jam?
How to clear the jam depends on where the jam is.
If the Jam is in Tray 1:
1. If you can see the jammed sheet, remove the jammed sheet by pulling it straight out.
2. If you cannot see the jammed sheet, open the tray 1 door and pull out tray 2.
3. Push down on two tabs to release the tray 1 panel.
4. Remove the jammed sheet by pulling it straight out.
5. Push up on two tabs to replace the tray 1 panel.
6. Replace tray 2.
If the Jam is in Tray 2:
1. Pull out tray 2 and place it on a flat surface.
2. Remove the jammed sheet by pulling it straight out.
3. Replace tray 2.
4. Press OK to continue printing.
If the Jam is in the Fuser area:
1. Open the rear door.
2. Remove any jammed sheets.
3. Close the rear door.
If the Jam is in the Output Bin:
1. Look for jammed paper in the output bin area.
2. Remove any visible media
3. Open and then close the rear door to clear the message.
It is possible that the paper may tear when clearing the jam. Be sure to clear any paper fragments that tear off.
Dec 16, 2010 | HP LaserJet CP1515n Printer
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to clear paper jam copier printer
The message Paper Jam may appear on the display if the Brother machine is not feeding paper correctly, paper scraps have become stuck in the print head path, the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
To resolve this issue, please follow the steps listed below:
  1. Disconnect the machine from the power supply.
  2. Turn the unit around and remove the Jam Clear Cover from the back of the machine by grasping it at the Center and pulling it straight away from the rear of the machine.
  3. Look for any paper scraps, jammed paper or foreign objects in the rear of the unit. If anything is found, remove it. Be carefull not to touch the feed roller.
3. Remove the paper tray feeder from the front and look inside for bits of paper and check the paper is flat in the tray.
4. Replace tray and back cover and all should be fine.
rover620
Sep 21, 2010 | Brother DCP-330C All-In-One InkJet Printer
Paper jam
Dear sir,
i am giving u setp to solved your problem,
Step one: Remove any loose paper.
Step two: Clear the jam from the back of the All-in-One
Step three: Clear the paper jam from the front of the All-in-One Step four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
Apr 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Minolta bizhub 200 All-In-One Printer Logo
96 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
