Question about General Electric Washing Machines
Ge wpse4270aoww no power to motor
Ge Wiring Diagram
Request the wiring diagram directly from GE.
Oct 24, 2017 | GE Refrigerators
My GE 1800 microwave turntable has stopped turning
There is a motor underneath the microwave that rotates the turntable. The motor may not be getting power or the motor may have failed.
Feb 11, 2013 | GE Profile Over the RanMicrowave....
15600 wiring problems
You probably have wrong voltage, or wrong wiring.
For example 15600 is 120Volt timer mechanism made by Tork and sold by GE.
This timer will not work with 240volts.
Other cause: Line and Load wires might be reversed.
Check circuit breaker.
Use non-contact voltage tester to see if power is live at timer.
Check wires at each terminal and make sure wire insulation is not under the screw plate.
Copy following link for wiring diagram:
http://waterheatertimer.org/GE-timers-and-manuals.html#15600
FYI, it is usually cheaper to buy T101 timer than GE15600, and then parts are more widely available and cheaper.
For example WG1570 clock motor for Intermatic T101 is $16.
Tork replacement motor is twice as much.
If you have 240Volt power, instead of 120Volt required by 15600, then you can buy Tork 201 clock motor and replace the 101 motor.
GE 15600 uses Tork p47 trippers.
http://www.globalelectricalsupply.com/Tork-Motors-p/motors.htm
Jun 17, 2012 | Hardware & Accessories
There is power in the power outlet but when turn the GE JVB96SASS Kitchen Hood. It doesn't work.
The next place to look would be the motor...is there power going to the motor??? Yes... then the motor is bad... no, then there is something inline interuppting the power...trace the circuitry and see where the power stops at...
heatman101
May 05, 2011 | GE JVB96SASS Kitchen Hood
My GE dishwasher will fill then it stops. The wash cycle never happens. After a while the heating element gets extremely hot, it drains, then says it is clean. The soap is still all over the door. It's a...
The pump/motor combination is stuck.
Disconnect power to the unit.
Remove the toe-kick panel at the bottom front.
You will see fan fins at the back of the motor.
Turn the fan fins counter-clockwise.Turn to the left and hold the position with a screwdriver. Then turn left again. You will feel when the stuck motor shaft frees itself.
After it frees,resume power and run the dw.
If it does not break free you will have to replace the pump and motor.
Jul 17, 2010 | GE Dishwashers
My GE Potscrubber Dishwasher doesn't spray water when it is turned on. It has power.
If you turn it on and hear a slight hum after water fill the motor is locked from non use. You will need to remove bottom panel and with power off you will see the motor right in the middle near the front. This is called a side winder motor because of how it sits. There are some blades you can turn to unlock the motor. Once the motor breaks loose which you will be able to tell when it does, turn power back on and let run thru complete cycle with heat dry in the off position. GE are about the only ones out there that will do this and it is usually from lack of use. Hope this helps.
Feb 21, 2010 | GE Dishwashers
Fan does not work,power board gets power ok
GE Zone have two boards Drive board and control board. Sounds like bad fan motor. I work on Zonelines and the motors go out more than anything else. Rusty
Jun 04, 2009 | GE Zoneline AZ28E12DAB Heat Cool Air...
GE dishwasher
If you can move the timer manually, then check the power to the timer motor. If you have power to the motor, replace the motor
Dec 14, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
Ge prodigy wpse4270aoww won't rinse or spin
try to clean out the water pump lines from pump to out to the drain
Feb 25, 2008 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
13 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
