Question about Frigidaire Ovens
PLEB30S9DC8 low heat
Low heat
  • Frigidaire Master
  • 5,323 Answers
Oven comes on and off intermittently or heats very little:
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
Why is the oven temperature incorrect?
The oven temperature control is usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.
Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.
On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.
Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
Posted on Apr 17, 2015
What can I do about the hobs overheating - when on, they are only on the highest heat and can't be turned down.
THE only solution is to replace the regulators that control the hotplates.
Could prove to be expensive.
Mar 01, 2015 | Belling Ovens
NEED TO WIRE A OIL FURNACE FAN FOR LOW SPEED IN HEAT AND HIGH SPEED IN COOL
Okay, I've got an answer for you.
If you get a Fan Control Relay that is DPDT, I think you can wire the Low Speed of a two-speed motor to the first N.O. contact, for Heat.
When the Relay trips, the N.O. contact will close, and the fan will run on low.
If it's a two-speed fan, these fans have two windings, the first for low, the second for medium, and both for High.
Wire both windings to the N.C. contact on the second half of the relay.
That way when the temperature drops below your setpoint, both fan windings will be energized and the fan will go nuts.
Of course, this means the fan will NEVER shut off.
And I still don't know why you need high speed in the Cool setting, when your thermostat isn't kicking the Relay.
Oct 10, 2012 | Honeywell R8285B1038 40 VA Fan Center with...
Bottom oven only heats to a low temperature
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 03, 2011 | Belling XOU592 / XOU593 Electric Double...
Turbo chef is not heating up, coming up on it reads, f8 low heat
the problem with f8 like you have said LOW HEAT
, IF the oven does not warm up in time , which is usually 8 min , it goes into f8 fault code
now please check the hi limit button , on the back of the oven , left hand side, bottom corner, if it reset and starts heating, please check bottom element and temp reading IR , IF it rises very quickly and the elemnt is glowing red , please switch off the unit at the power point , you have problem with the solid state relay, if the temp is slowly rising , then you might only have an issue with the hi limit reset button thermostat, FIRST JUST CHECK THE RESET BUTTON
Jul 03, 2010 | TurboChef C3 Single Oven
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Oven not heating properly
you sure you have 240volts at the unit??? chk for 120+120 volts to get 240volts,one leg out and you'll have little to no heat condition
Jun 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Low temp causes heating coil to spark and leave white residue
You need a new heating element fitting.
Do not use it until it is fixed.
The white powder is from the inside of the element.
Please rate this solution.
Ta.
Dec 09, 2008 | Ovens
About my turbochef toster oven it has f8 low heat problem
there is a high limit reset button on the back of the oven .reach around left side if you are facing oven. if that is it but it trips again you have other issues. if that is not it you have other issues possibly k4 k5 ssr or element problems
Nov 15, 2008 | TurboChef TORNADO Electric Oven
Ovens Logo
59 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
