Question about Ford 555 backhoe
Steering wheel turns, but nothing happens
Key wont turn or release the steering wheel
I'm not familiar with the Mercedes, but first of all, NEVER turn your wheels all the way, it'll cause damage sooner or later, you kind of found this out already. Next, try getting to the fuse center under the dash and probably under the hood of the car, check all your fuses with a digital volt meter, replace any that are bad.
Your last statement is "won't start" does the engine spin? or nothing at all happens when you turn the key? If your sure the battery connections are all tight and clean the next step I would do is plug an OBD II scanner in and get any codes that have popped up in your computer, if there aren't any, then my next suggestion would be to start checking into the ignition system, If you forced you key to turn in anyway when you had your wheels locked to the side, you could have damaged the electro-mechanical components in the steering column.
Jul 19, 2016 | 2004 Mercedes-Benz C-Class
When I turn the steering wheel nothing happens. It turns, but nothing.
Something inside the steering column or at the end gear is not connecting. The connection at the wheel could also be
Loose
May 19, 2016 | Cars & Trucks
My key will not start my car...its in park and the steering wheel is in the lock position...and the head lights aer not working
Can you turn the key at all? If not, sometimes the steering wheel can be binding on the key release. Wiggle the steering wheel left and right while trying to turn the key. If it releases and the vehicle starts, you have corrected the issue. If you can turn the key and nothing happens, you say you headlights don't work....does anything else. You could have a dead (or very low) battery.
Jan 13, 2015 | Cars & Trucks
I have a ford focus 2003- today when I exited the car nothing was unusual..when I went to try to go to work the key will go in ignition but won't turn AT ALL. Anyone know what I can do to fix it?
your steering wheel has tension on it - are your front wheels parked against a curb or were you turning your steering wheel while you shut off the car? Try pulling hard left and turning the key. If that doesn't work, pull hard right while turning the key. You may have to pull really hard if you are a smaller person.
Jul 06, 2014 | 2000 Ford Focus
I put my key into the keyhole near the steering wheel so I could start the car, but for some reason my key won't turn, like it's stuck, what can I do to fix that?
Try moving your steering wheel to the left then jiggle the key until it releases, if no luck try the same thing moving the steering wheel to the right, or combination of both ways, If this works then there is nothing to worry about, it can happen almost to any vehicle, you are just in between the wheel locking mechanism and the ignition start or the removal of the key, a common problem in the design of the wheel lock, to prevent it from happening again, just have your steering wheel were you want it before starting or turning off you car. Rick
Aug 21, 2011 | 2009 Acura TL
Steering wheel locked, cannot turn key to start, jiggling steering wheel not effective. turned battery on and off, inserted wd40, nothing works. help!!!
Try holding your steering wheel hard to the left as you try to turn the key. If this doesnt work try holding it to the right doing the same thing. Something happened to where the steering wheel lock engaged and that will prevent you from using the ignition key. Try this
Feb 05, 2011 | 2007 Hyundai Sonata Limited Sedan
Key wouldn't turn on 2002 ford explorer b/c steering wheel seemed to be locked up.
This is common, if the wheel was turning at the time of the key being turn off it will put preasure on the wheel lock pin, this causes the lock to be diffuclt to turn, what happens is the steering wheel has a plate inside column, this plate has a lot of slots going around it, so when you turn the key off a pin comes up and goes into one of the slots that algin over it and if the wheel turns back the slot hits the pin with enough force to hold it, so when you turnn the key the linkage pulls the pin down bbut if its held the pin wont move and key wont turn unless you move the wheel which in turn moves the lock wheel away from pin, nothing is wrong its just something that happens,hope this helps.
Oct 31, 2010 | 2002 Ford Explorer
Transmission issue
turning the steering wheel lock to lock can NOT damage anything in the transmission but if you hold it for extended periods of time you can damage the power steering pump.
Apr 04, 2010 | 1999 Dodge Intrepid
2005 Mercedes telescopic steering wheel will not go up or down but will go in and out. I hear a gear turning but nothing is happening.
during you selection adjusting the steering wheel in and out and if you hear the gear moving but you steering does not move than the gears are prob. need replacing, worn out gears.
Jun 17, 2009 | Mercedes-Benz C230 Cars & Trucks
STEERING WHEEL DOESNT WORK
Find the controller setting within the Game as there is a few settings for wheels. Find the setting that suits your wheel configuation and set it. Should be go to go.
Apr 20, 2008 | Logitech DRIVING FORCE FEEDBACK STEERING...
Garden Logo
50 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
