Question about Avaya 5420 Digital Telephone 700381627
Changing the time
I need help changing the time on our phone?
Change Time
THe older norstar systems you had to go into programming to change time and on the newer systems press feature * time on your phone and follow the prompts. On the older systems go in to programming press feature ** 266344 (config) then pswd 23646 (admin) on your key pad this gets you into programming press next until you get to change time. You need an overlay which can with your phone system manual. If need more info please ask agian hope this helps.
Nov 17, 2009 | Nortel Norstar 16-Line PBX Speakerphone
We have a Norstar T7316 at work and need to change the time can anyone help?
Two ways to change time on old and new norstar. Old go in to admin programming and step to time adn date then change time. New system go to t7316 phone and push feature key plus **time then change time
Sep 30, 2009 | NorStar T7316E Corded Phone
Re-set date and time on display
Have you tried:
Feature **23646 password 23646 (if you phone admin hasn't changed this) and then select set day& time then change there
Feb 23, 2009 | NorStar M7208 Corded Phone
Change time
I assume you got this fixed? But, Euro style is a Partner phone, and Merlin is a merlin...contradictory terms.
Aug 11, 2008 | Lucent Legend MLX-28D Corded Phone
Changing time on my Mitel Superset 4025
The only way to change the time on your individual phone is to change the time on the entire phone system.
Mar 09, 2008 | Mitel Superset 4025 Corded Phone...
Cant change time on phone
time & date
Your phone needs the time and date for the datebook.
To synchronize the time and date with the network:
Press - > Settings > Initial Setup > Time and Date > Autoupdate
> On
To set the time and date: Press - > Settings > Initial Setup
> Time and Date > time or date.
To choose an analog or digital clock for your home screen,
press - > Settings > Personalize > Home Screen > Clock > Analog or
Digital.
hope this helps
riz.
Nov 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
How do you change the Time?
This is a phone system phone. The time is stored in the main control unit, not the telephone. You will need instructions for changing the time in your system and the phone's part number will not help you. Your phone system should start with the part number "KX-TGA" KX-TGA???? Here is a link to a site that has time change instructions: http://www.tel-programmer.com/Time%20setting/panasonic_time.htm
Sep 20, 2007 | Panasonic KX-T7630 Corded Phone
Time settings
This phone is a proprietary business telephone. It works on several different Panasonic phone systems. You may need to know exactly which phone system you have and the phone's model number will not help. Here is a link to a web site that covers time change on many different phone systems. http://www.tel-programmer.com/time_setting.html
Aug 15, 2007 | Panasonic KX-T7730 Corded Phone
Avaya 5420 Digital Telephone 700381627 Logo
21 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
