Question about GE PFE29PSDSS 29 cu. ft. French Door Refrigerator with Spillproof Glass Shelves, Gallon Door StoraHumidity Controlled Crispers, Drop-Down Tray and Auto-Fill Ice/Water Dispenser
Ice dispenser sticking
Ge pfe29psdss
Have a ge profile refrigerator went completely dead,repair man replaced mother board and control panel still not working, fridge is only 14 months
If there is no power after the repair man replaced the board and panel, the repair job is not complete. Have the repair man finish the job.
May 03, 2016 | GE PFE29PSDSS 29 cu. ft. French Door...
Take PFE29PS out of demo mode
Hold the lock and precise fill buttons for several seconds and a prompt will appear to disable it.
Sep 17, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
Ge profile refrigerator temperature setting
Sounds like the damper controller is stuck due to obstruction or isn't working at all and needs replaced.
Jul 31, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
How to get ice dispenser panel off front of door?
if its a whirlpoo at the bottom of the trim there are two slots use a flat head pull down and pry out
Jan 21, 2010 | Whirlpool Freezers
Not pumping water to icemaker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 08, 2009 | GE Freezers
Why is there water in the ice bucket of my ice maker? It is a GE side by side, but without the dispenser in the door.
hello, how are you, if there is water in your ice bucket, it seems as though when your icemaker sends a signal to water valve to give water, your water valve is sending too much water into icemaker, the solution would be to replace water valve which is behind the refrigerator at the bottom. it should be blue in color which clear plastic tubing connected to it. This happens when the water valve solenoid doesnt close completely.
Sep 13, 2009 | GE Freezers
TFXW24RL ICE FALLS EVERYWHERE ICE SHUTE PERISHED TO GUIDE ICE CAN I REPLACE PART IN AUS
Here's one place you might can find the part. Post your model number in the proper place and select the dispenser parts. You'll have to go through the ordering process to see where they ship. http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Aug 19, 2009 | GE Freezers
GE S/S Refrigerator model GSS20IEBWW auger not turning
Take a hair dryer and heat the auger drive gear. These will sometimes get moisture on them and freeze up.
Turn the refrigerator off first. Then remove the ice bin. The "U" shaped drive will be in the back.
After you have heated it thoroughly, try to move the gear manually. Resume power and try it again.
May 19, 2009 | GE Freezers
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
GE PFE29PSDSS 29 cu. ft. French Door Refrigerator with Spillproof Glass Shelves, Gallon Door StoraHumidity Controlled Crispers, Drop-Down Tray and Auto-Fill Ice/Water Dispenser Logo
99 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
