Question about Sound Logic Audio Players & Recorders
Soundlogic ipod standby mode
How do I connect my soundlogic blue tooth speaker to my iphone
Connecting any device to an iPhone via bluetooth is a fairly straightforward process:
1) Make sure your device (soundlogic speaker, in this case) is on and in "discoverable" mode. Your speaker should have come with instructions on how to do this; It's a different process per device, so I can't offer anything specific in regards to doing this, sorry.
2) Go into the Settings on your iPhone, then click on "Bluetooth". If Bluetooth isn't turned on, turn it on, then click on your device under "Devices". If you don't see it, make sure you're close enough to the speaker and that the speaker is in "Discoverable" mode. Your phone will pair itself with your speaker, and from this point on, your phone should automatically connect with your speaker anytime both your speaker is on and your phone is on with bluetooth enabled. Hope this helps!
Apr 15, 2015 | Cell Phones
Where can I find a printable User Manual for a Soundlogic XT 2600mah power bank
There doesn't seem to be any owners manuals available online?
quite a few youtube videos...
SoundLogic XT PowerCell ' Unboxing & Demo: http://youtu.be/YfkVB26EmIM
or you could try contacting the company... SOUNDLOGIC Contact Us
Mar 06, 2015 | Electronics - Others
Connecting wifi soundlogic xt android touch screen netbook / tablet
I purchased a soundlogic xt netbook and I can't connect to the wifi. I did everything the instructions said, but still no luck.
Nov 06, 2012 | Coby Tablets & eReaders
Cant adjust the time o the clock
  1. Select Clock Adjustment item during Menu mode (In Standby mode see below for standby mode explained). Select the "Clock Adjust" display.
  2. Enter Clock adjustment mode. Press and hold the control knob for at least one second. The clock will blink.
  3. Adjusting the clock. Push the control knob towards the left or right to select hours or minutes. To adjust each item turn the control knob or push it towards up or down.
  4. Exit clock adjustment mode. Press the (FNC) button.
  • Turn on the power.
  • When the power is ON, select a source.
  • SRC Select mode 1: PRess the (SRC) button and then turn the Control nob or push it toward left or right.
  • To determine the selected source, press the Control knob.
  • SRC Select mode 2: Pressing this button each time switches between sources.
  • Turner ("Turner"), USB or iPOD ("USB" or "iPod"), CD ("Compact Disc"), Auxiliary input ("AUX"), and Standby ("STANDBY")
  • Press at least 1 second to turn off the power
Nov 10, 2010 | Kenwood KDC-MP538U Car CD/ MP3 Player
How do i charge my ipod
To charge the battery, choose one of the options below:
  • Connect the device to your computer (not your keyboard) using the included cable to charge the battery and sync. Your computer must be turned on and not in sleep or standby mode. If the device is connected to a computer that's not turned on or is in sleep or standby mode, the battery may drain.
  • Connect iPhone or iPod touch to a power outlet using the included cable and a USB power adapter to charge the battery.
An icon in the upper-right corner of the screen shows battery charging status. If you charge the battery while syncing or using iPhone or iPod touch, it might take longer to charge.
Note: If using a portable computer, make sure it is plugged into power and that the lid or display is open. If the lid is closed, the computer may go into standby, sleep, or hibernation mode and iPhone or iPod touch may not charge.
Important: If iPhone or iPod touch is very low on power, it may display one of the following images indicating that the device needs to charge for up to ten minutes before you can use it. If the device is extremely low on power, the display may be blank for up to two minutes before one of the low-battery images appears. If you don't see the white charging or plug icons, your iPhone or iPod touch may be connected with a FireWire cable. Disconnect the FireWire cable and connect the iPhone or iPod touch to a USB cable or dock.
that should be everything you need to know about charging an iPod Touch. If you require further assistance please feel free to followup with additional comments. If this solution solved the problem please feel free to rate it. Thanks and have a great day-Midwest-Tek
Aug 20, 2010 | Apple iPod touch Second Gen (8 GB,...
How do I set the clock on Accurian IPod docking alarm clock
When in standby mode (press and hold power button to enter standby), press MODE. Now press |<< TUNE/SKIP >>| to set 12-hour or 24-hour display mode. Press MODE to confirm display setting. The display flashes. Press |<< TUNE/SKIP >>| again to set the hour, then press MODE. Press |<< TUNE/SKIP >>| to set minutes, then press MODE to confirm the time.
Nov 12, 2009 | Digital Products International ILIVE...
My friend stole my itouch and chaged my password
You will have to put it into DFU mode and wipe the thing. Here's how:
Step 1: Hold down the “Home” button
Step 2: Hold down the “Standby” button
Step 3: When it says “slide to turn off”, ignore it. It should restart with a blank screen. Look at iTunes, and your device should be removed. Now lift the Standby button, while still holding onto the Home button.
Step 4: Keep holding the Home button until the iPod reconnects on iTunes. When the device shows up in iTunes, that’s when you’ll need to lift up your button. If you wait any longer, it will go into Recovery Mode, and that’s not what you want. Your iPod should be blank.
Step 5: Now iTunes will tell you that the iPod Touch is in Recover Mode.
May 04, 2009 | Apple iPod touch
Product RS2767i help
you need to turn it on at any mode to charge your ipod,as it has no charge function at standby mode .
Mar 27, 2009 | RCA Audio Players & Recorders
Ipoda1236
DFU means:
Device Firmware Update, hence it’s a mode where the iPod Touch device will be made to force restore into whatever versions it’s given with.
If you're not trying to 'restore' it, take it out of this mode
[If you are, you should be installing firmware]
Here are instructions that are Windows & MAC compatible:
[remember this is HOW to get to DFU mode
Before you begin, turn on your iPod Touch (make sure it won’t auto lock, to prevent mistakes), and connect it to iTunes. Once iTunes shows your device, perform the following steps:
______________________________________________________
If you didn't know exactly how you got where you are, or you want to change the mode, use the directions to guide you.
If that doesn't solve it, post back with more details
Feb 20, 2008 | Apple iPod nano
29 people viewed this question
Top Sound Logic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sound Logic Audio Player and Recorder Expert? Answer questions, earn points and help others
