Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Ultracare 2 washing machine leaks from bottom
  • 57 Answers
One of your hoses has split or cracked or simply come loose also take lid off and check where soap drawer water pipes are
Posted on Jun 23, 2009
Hoover ultracare hc6 150m. Changed drum bearings today .but pulled of spade terminals to power switch .Established live and nuetral feed to switch ,but unable to establish switching pair polarity..Wires...
Now THIS is strange! I hunted HOOVER and got this:
"Your search for "hoover ultracare hc6" resulted in no products."
and
"Your search for "hoover ultracare hc6 150m" resulted in no products."?
Even a GOOGLE SEARCH had no real hits for:
hoover ultracare hc6 replacement parts
...had ZERO results... well actually there were some hits but no actual "part sellers" and the DO want to make money!
Dec 06, 2017 | Hoover UltraCare HC6 150M Front Load...
Hoover ultracare 1300 large load stopping mid cycle at a variety of different points and having to be manually stopped and started again at another point to complete the wash
Checkout your filter at the bottom of the machine, undo the bottom flap below the door, front. Plug off the wall mains socket. Be prepared for a lot of water so keep plastic bag, towels ready. Unscrew the plug you see to make water flow into bag; when all water has been disposed off, clean this filter & inside, refit carefully.
Feb 13, 2010 | Hoover UltraCare HC6 130M Front Load...
My Hoover Ultracare 1300 washing machine has just stopped before the spin - full of water. I have tried several options but can't get it to move at all from that. It will rinse and move clothes around, but...
Yes. the pump may be blocked. look at the bottom of the washing machine front and you will see a flap undoo this and take out any bitts stuck in. Caution. Make sure the washing machine is un pluged and when you unscrew that plug. all of the water will come out of the machine. Best to do it outside. If that dose not work it means the pump has blown.
Dec 15, 2009 | Hoover UltraCare HC6 130M Front Load...
Hoover washing machine wont spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Nov 01, 2009 | Hoover UltraCare HC6 160E Front Load...
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Whirlpool Ultracare Doesnt spin out well
this is a direct drive unit it will spin or make alot of noise. do you have the spin speed set correctlly to what your washing if so look under unit and check motor coupling and look for any signs of transmission oil leaks
Nov 10, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Hoover ultracare 1500 not emptying
Suggestion: First plug off the wall. Remove the back panel of the machine. Check to see it the thin tube going from the top control panel to the exit side below the machine is block free. To check disconnect this from the top and blow into it. It should not blocked, refit. This is the water level control. Secondly check out your pump.
Sep 17, 2007 | Hoover UltraCare HC6 150M Front Load...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
148 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
