Question about Bretford Laptop Storage Cart LAP30EULFR-GM - notebook storage cart (S3284947)
Change fuse bretford cart
Replace fuse
Price of cheaper priced ipads
Could you be more specific. Taking a wild guess if you are looking at for a cheaper priced iPad then Apples own refurbished site is a great place to start. Ebay is another place if you want to sample the used market. As a precaution make sure you get a model with enough storage, 16gb IMO is too small, a few books, a game or three and some songs and now you're stuck with not enuff storage and no means to upgrade without buying another model.
Sep 01, 2014 | Apple Computer Apple Bretford PowerSync...
No catridge scx-4521f
Dear
On the left front (drum side) of the cart there is a notch, bellow the cart. fuse. If it was broken it can not s/w on the micro switch fitted on the base, replace the cart.
Thanks.
Jul 07, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Changing fuse on Bretford Mobility Cart 20
First thing to check is if the power cable has been pulled out of the power supply under the top surface of the cart. Ours was pulled up just enough to not power the cart, even though it looked like it was plugged in. If that isn't the problem. then you will find two wing nut screws holding the power supply unit in place. Unplug all three cables running to the power supply, then unscrew the wingnut screws. Lift the black rubber cover off the surface and you can then lift the power supply out. You will find a fuse location you can access with a flathead screwdriver.
Nov 13, 2013 | Bretford Mobility Cart 20 for MacBook and...
Bretford iPad Cart Static Electricity problem
This was straight from a Bretford tech:
There are no capacitors or anything that can hold a charge on the cart itself. The only thing that we've been able to come up with thus far is that dry air in the schools may help generating static electricity. Common precautions would be 1. make sure the ground plug is still on the cord. (This can get broken off if the cart is moved with the cord still plugged into the wall.) Plugging the ground cord in won't help however if the person has to grab the door handle to open the door to get to the wall outlet. 2. If the air is dry (ie: people get shocks even without the cart or the problem goes away in the spring when the humidity goes up), gently push the metal of the cart handle against the door frame prior to reaching for the door handle. This will discharge any static electricity that was built up as the person walked with the cart safely to the door jamb prior to the person reaching for the door handle.
Nov 20, 2012 | Apple Computer Apple Bretford PowerSync...
Drawer 2 doesn't sink
Don't really know the hardware, all I can suggest is since you have managed to sync one ipad have you tried one ipod. The standard response for something that has many potential factors causing a problem is to try syncing each one of the ipods separately, you could find that one of the ipods is causing the whole lot to fail. It will take some time to do but if it is just the one ipod causing it you can remove it and then try syncing the rest. Hope this makes sense?
The other thing is are all the ipods running the same version of the iOS, I saw from the user guide of the Cart that you need to deselect the check for new software updates automatically, could it be that one of the ipods is running iOS 3 and the rest are running iOS 5. You can check this under settings then general and then about and then version.
Hope this helps.
Nov 14, 2011 | Apple Computer Apple Bretford PowerSync...
My samsung printer is now working . i mean i refill the cartriage but i could't take the print out. its showingthe error for "No cartriege" whatcan i dod? Help me
did you replace the fuse on the cart. it blowes when toner is out .new fuse will reset printer functions. fuse is on front of cart. real small you can miss it real easy. replace with same amps on fuse. Do not go over.
Aug 12, 2010 | Samsung ML 1610 Laser Printer
My MFC-210C always says replace ink.
Try this: Unplug machine from power. Wait 5 min.  Open scanner cover and take the carts out of the holder. Close cover. Plug machine to power. Machine will cycle and demands the carts. Use all NEW carts: Insert carts as demanded and answer question shown on display.
Always print until machine STOPPS printing because of EMPTY cart. Change cart then and machine will print the rest of job!
Plz, never change carts when it says NEAR EMPTY: This will cause a lot of trouble ;-)
Nov 18, 2007 | Brother MFC 210C All-In-One InkJet Printer
Bretford Laptop Storage Cart LAP30EULFR-GM - notebook storage cart (S3284947) Logo
Top Bretford Computers & Internet Experts
David Payne
David Payne
Are you a Bretford Computer and Internet Expert? Answer questions, earn points and help others
