Question about Arris Dct6416 Phase Iii Dvr Digital Cable Receiver Box Dct 6416
Camera connect to tv
How to connect my camera to the tv
Where do I connect the wires from video security camera to my tv
The yellow RCA connector is the video line - connect this the VIDEO IN on your TV
The white or red RCA is the audio line - connect this to the AUDIO IN on your TV
The black tube like connection is the POWER to the camera - there should be a separate charger adaptor to connect this to.
Feb 16, 2016 | Home Security
How to hook up security camera
Basically, all you need is:
1- Power-up the camera.
2- Select video input 1 or 2 on your TV.
3- Run a cable from the camera to the TV
4- Connect the cable coming from the camera to video input 1 or 2 on your TV.
Please note:
The cable you run from the camera to the TV has 2 Ends.
One End connects to the camera (BNC plug) the other End connects to the TV (RCA yellow plug)
I hope this helps. If not, provide the model# for the TV and camera, and if I come across your post I will be Happy to contribute.
Best of luck
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD Televison & Video
How to connect camera to sony bravia tv.
Connect your camera in RCA cable (the one with a red, white, yellow connector for audio/video connection). Then connect it to your Bravia TV.. Set your Bravia TV in video mode, (the mode when you're playing DVD player in your TV)..
Note: Your video mode depends on where you connect your RCA cable. There are up to 3 video mode, Video-1,Video-2,Video-3
Then turn on your camera..
May 22, 2011 | Cameras
I cannot show pictures on my tv from my sony 120 . I have the cords and the input on the tv but nothing happens when I try to show them???The manual suggest to delete the usb port???
You can either use the supplied A/V and USB Multi connector cable for connecting the Camera to the TV. Connect the Yellow cable to the Yellow port on the TV for Video and the Red and White for audio. Then select the proper input on the TV where the cable is connected.
You may also connect the HD Out of the Camera to the HDMI Input on the TV using the compatible HDMI cable for the Camera.
Before connecting the Camera to the TV, you may have to change the settings in the Camera depends on the TV type.
1. Component Settings from the Main Settings 2 Menu of the Camera should be set to HD or SD depends on the connection. Also depends on HDMI (HD) or A/V (SD) video connection.
2. Video Out Settings from the Main Settings 2 menu of the Camera should be set to NTSC or PAL depends upon the color system of the TV.
Try changing the settings in the Camera and connect it to the TV to view the images.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Unable to view moves from the camera on my TV set.
this could be correct as the signal for the Camera LCD screen is now being sent to what ever device is connected on the TV out cable.
ensure your connection is
Camera - TV out
TV - Video in.
ensure that your TV is set to the correct channel or input setting to view the signal from the camera.
Nov 14, 2009 | DXG Technology DXG-565V Flash Media...
What camera setting is required to show photos on TV. I have the video cable connected.
Set camera in playback mode, connect AV cord in camera and hook it to AV-in of TV and select that AV input with TV remote to view camera picture in TV as its being shown in camera LCD.
Sep 19, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
How do I connect my jvc gr-ax25u camera to my tv
I have the same camera. There is a cable that came with the camera. It has what looks like an S-video plug on one end that you connect to the camera. The other end has the AV (white & yellow)plugs that you connect to your TV. Your TV has to (of course) have AV connections in order to connect.
Mar 14, 2009 | JVC Video Cameras
View images on TV
Hi again: About the black and white pictures on the TV... not normal I think... I have never seen your camera model but a common thing can happen to any camera!! Have you already tryed to connect the camera to your TV using a AC Adapter (D-AC8 in your case)? Are the connections Ok? You're connecting following the manual instructions? If you don't have it download it... :) http://www.pentaximaging.com/files/manual/OptioS5i_Web.pdf Regards
Sep 08, 2005 | Pentax Optio S5i Digital Camera
Arris Dct6416 Phase Iii Dvr Digital Cable Receiver Box Dct 6416 Logo
10 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
