Question about Canon imageCLASS MF9280CDN Laser Multifunction Printer - Color - Plain Paper Print - Desktop Printer, Copier, Scanner, Fax - 22 ppm Mono/22 ppm Color Print - 2400 x 600 dpi Print - 22 cpm Mono/22 cpm Color Copy LCD - 600 dpi Optical Scan - Automatic Duplex
E000001 - Canon imageCLASS MF9280CDN Laser Multifunction Printer - Color - Plain Paper Print - Desktop Printer, Copier, Scanner, Fax - 22 ppm Mono/22 ppm Color Print - 2400 x 600 dpi Print - 22 cpm Mono/22 cpm Color Copy LCD - 600 dpi Optical Scan - Automatic Duplex
E000001-0002
E000001-0002 means u have problem with heater unit.
The sub thermistor detects about 295oC or higher.
verify the problem may be yours main thermistor become dirty with toner just clean that and reset error.
Jul 22, 2014 | Canon ImageRUNNER 3570 Copier/Printer
Canon ir2318 error E000001-0001
Fixing temperature rise detection by sub thermister error, check the machine using switch off for 5 min and Switch On, if it still showing same error after switching On means you have to replace the fixing film assembly
Feb 04, 2013 | Office Equipment & Supplies
Canon image runner 2420l error message **E000001-0001
Canon Digital Copier IR2420L.
in this we are receiving the error Restart the machine if problem persists, call service rep **E000001-0001
What is error code E000001-0004 and E000001-0010 for canon copier 8500
there is a good possibility that the main thermistor and the sub thermistor has gone bad or is dirty. also it might need adjusted to be better placed next to the upper fixing roller
May 19, 2010 | Canon imageRUNNER 8500 Copier
I keep getting error codes
i am getting error E000001 -0010
Sep 16, 2008 | Canon imageRUNNER 5570 Copier
Canon imageCLASS MF9280CDN Laser Multifunction Printer - Color - Plain Paper Print - Desktop Printer, Copier, Scanner, Fax - 22 ppm Mono/22 ppm Color Print - 2400 x 600 dpi Print - 22 cpm Mono/22 cpm Color Copy LCD - 600 dpi Optical Scan - Automatic Duplex Logo
old marine
old marine
