Question about Anycom MILOS-9 Bluetooth Headset
How to pair with an iphone
My phone stays in discover mode
I can not pair the jabra sp5050 to my iphone4. my problem is that my iphone continues to search for the device, with no luck. My phone says that it is dicoverable. I have also tried with other cell phones...
You have to put the speaker phone into pairing mode it is meant to enter pairing mode automatically but from what you are saying it has not done this or has timed out.
Press the answer /end button for 7 seconds to force the speaker phone to go into pairing mode then ask the phone to discover bluetooth devices.
https://www.manualslib.com/manual/364943/Jabra-Sp5050.html?page=7#manual
Jul 05, 2017 | Jabra SP5050 Bluetooth Headset
Just bought a used 2004 with handsfreelink. tried pairing my iphone 4 to it by following directions with voice commands and 4 digit passcode. system wouldn't pair and can't get radio on in any mode(cd,...
When you try to pair your iPhone 4, what message does the iPhone prompt you after you enter in the passcode?
Have you tried making sure your iPhone was disconnected from any other headset around you?
Mar 07, 2011 | 2004 Acura TL
Iphone 3GS not pairing to plantronics voyager 520
Without turning the headset on, turn the bluetooth on for the phone. Select the headset that is paired, and select Unpair. Then turn bluetooth off. Put the headset into the "discover" mode, by holding down the power button until the light flashes red and blue. Then turn the bluetooth on for the phone, and it should "discover" it. It should ask for the passcode, normally 0000. Once you enter that, it should pair. After that, you should be alright. You can turn the headset off and back on again and it should connect right away.
Hope this helps.
otherwise try this : http://www.plantronics.com/media/media_resources/easytopair/
Jan 12, 2011 | Apple iPhone 3GS Black (16 GB)
My iPhone 4 bluetooth won't discover the plantronics 220 Bluetooth earpiece for pairing. Both devices are on including bluetooth on my phone
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode ***(usually you have to hold the power button for 7-10 seconds)***
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 31, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How to conect Motorola H500 Bluetooth Headset to Iphone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Nov 09, 2009 | Motorola Mobility Bluetooth Hands Free...
Not paired, Motorola Blue tooth H300 to iPhone 3G S
hi
when the bluetooth id discovered it has to be registered with the default code of 0000 over the handset to be paired
hope this helped
cheers
Jul 07, 2009 | Dual Electronics CECT P168 Cellular Phone
My iphone is not discovering my blue tooth head set, why?
Make sure the bluetooth headset and the iPhone are both in pairing mode. Set the headset in pairing mode first and once set then go and turn on the iPhone bluetooth. It may take about 30 seconds to a minute for it to find the headset. Once the iPhone has found the headset make sure you select it on the phone and it will pair from there - Hope this Helps!!
Jun 08, 2009 | Apple iPhone Smartphone
Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Jun 02, 2009 | Motorola Mobility HS850 Consumer Headset
My iPhone 3G does not discover my Motorola H500.
Try this link. It solved my issue www.scribd.com/doc/280088/motorola-h500-bluetooth-earpiece-manual. Basically what you need to do is power the earpiece off. Make sure that your IPhone is not currently attempting to discover bluetooth devices (i.e. Bluetooth is OFF). Hold the On button on your earpiece (it has the symbol of a phone on it) for 6-10 seconds. The light on the earpiece remains lit. Now your earpiece is in discovery mode. On your IPhone, go to Settings, General, Bluetooth. Turn Bluetooth ON. Now your phone and your earpiece are both in discovery mode. When you see "Headset" listed, select it and enter the password "0000". Your IPhone is now paired with your H500 headset.
Mar 24, 2009 | Motorola Mobility H500 Wireless Headset
Discovering a Motorola H721 headset on my Iphone
open the boom flip. Press and hold both volume buttons and the call button for more than 10 seconds. The indicator light flashes 3 times and then becomes steady lit. The headset is now in pairing mode.
Nov 26, 2008 | Motorola Cell Phones
Anycom MILOS-9 Bluetooth Headset Logo
Top Anycom Radio Communications Experts
Michael Vincent Cruz
ray gallant
Are you an Anycom Radio Communication Expert? Answer questions, earn points and help others
