Question about Poulan Weedeater/Electric Trimmer 4.1 Amp
Same Problem Brand new out of the box. Mixed the fuel, was a little hard to start. Got it to run and it idles fine. When you start to weedeat, it dies. Going to try to adjust the carb.
  • 155 Answers
Try winding the mixture screws out a little
Posted on Jul 26, 2009
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Weed eater bogs out at full throttle
Make sure fuel is mixed correctly, make sure the choke isnt stuck on aswel, ive had it happen to me before when the little blue leaver sticks and it wont rev out properly.
Apr 02, 2013 | Husqvarna 128 LD Weedeater
I have a weedeater brand hedge trimmers 18 inches long. I rebuilt the carb and replaced fuel lines and filter. The unit ran fine until the last two times that I have tried to use it. It will run and...
have you checked the fuel plate thats in the bottom of carb? they tend to dry up and because rubber the 2 stroke fuel makes it dry and shrink, then it no longer pumps fuen into cylinder
Mar 01, 2011 | Weedeater Gas Powered Hedgetrimmer...
I have a 2004 6cycl. Tralblazer that runs fine at idle. After it warms up it still runs fine at idle and hard accelleration. But running at tempature at just enough throttle to stay at speed around 60 mph....
This engine has variable valve timing that uses oil pressure. have had to replace several engines to fix the problem. Try changing oil and using a little thicker oil. example 10w40 instead of 10w30
Jan 10, 2011 | 2004 Chevrolet Malibu
My stihl weedeater starts and idles fine but does not get power.
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crack or split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jul 07, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Slight miss, starts a little hard then runs fine rough idle from time to time
It sounds like its out of time move the distriutor a little bit
May 10, 2009 | Jeep Cherokee Cars & Trucks
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
My weed eater will start but when I push on throttle it dies
well take the spark plug out take some WD40 and give it a shot inside the unit, remember to keep the unit level when hitting the throttle and allowing it to warm up for a few minutes before use also make sure where your choke lever is. also when starting I start it on the ground like most manuals state and leave it idle on the ground for a minute before picking it up and then when I pick it up I make sure that the gas tank is tilted towards the ground so there is no room for air to get into the filter causing and disturbance while the unit is warming up.
Nov 15, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Poulan Weedeater/Electric Trimmer 4.1 Amp Logo
649 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
