Question about HP Photosmart 6520 e-All-in-One
Printer keeps showing off line and will not print
Prints ok then will not print
  • 3 Answers
Get a technician
Posted on Mar 21, 2014
I can download solutions center also it keeps showing no color cartridge so it wont print in color
Try to clean the cartridge nozzles. On your printer operator panel, press Setup button, press Ok -> Press the arrow buttons until Clean Cartridges appears, and then press Ok. A page prints, forcing ink through the print cartridge nozzles to clean them. Try to print your document again.
Apr 30, 2011 | Lexmark X4650 InkJet Printer
Printer is not printing right it keeps saying
ok! printers are the most difficult machines to work with you must be very patient ok! Now just turn your printer off and then turn on make sure that your computer recognizes your printer driver if not you are going to run in a whole lots of trouble once thats cool do a printer test page and if that doesnt work you need to reply back to me ok!
Mar 26, 2010 | Kodak ESP 5 Printer
Cannot print keeps saying clean printer cannot find info to do it
Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
Checking the print quality
If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
1 Press Ink.
2 Press or to select Test Print.
Press Menu/Set.
3 Press or to select Print Quality.
Press Menu/Set.
4 Press Color Start.
The MFC begins printing the Print Quality Check Sheet.
5 Check the sheet to see if the quality is OK by following these steps:
Color block quality check
The LCD shows:
6 Check the quality of the four color blocks on the sheet.
7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
OR
If you can see missing short lines as shown below, press 2 (No).
The LCD will ask you if the print quality is OK for black and three colors.
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
8 Press 2 (No) for Black or three colors
with a problem.
The LCD shows:
Press 1 (Yes). The MFC will start cleaning the print head.
9 After cleaning is finished, press Color Start. The MFC will start
printing the Print Quality Check Sheet again and then return to
step 5.
10 Press Stop/Exit.
There is more, but too long to put here.
Jan 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc490cw printer show offline and erro
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Aug 06, 2009 | Office Equipment & Supplies
Cannot print maps or directions from Mapquest or Yahoo or certificates from on-line surveys. All used to print. Recent change is is adding Adobe 9.1. Advice, please? Thanks!
First start by trying to print from the file menu. A new window will open showing you a choice of printers, select your printer and select ok.
If it prints then possibly Adobe changed your default printer settings.
Again open the printer and faxes folder.
If there is more than 1 printer showing, Select the printer you want to use as the default and select ok.
Hope this helps, Have a great day
Apr 08, 2009 | Dell Dimension 2400 PC Desktop
Printer does not print. allplugs are ok
Dose the printer show up under printers and faxes? Dose it show the words ready or work off line under the printer? If the printer shows work off line, right click the printer and take the check away from work off line. It should change the wording to ready and start printing.
Nov 19, 2008 | HP Computers & Internet
On Line Error
maybe..online error usually is a communications issue..you might want to isolate the printer from the computer power line, if that's an issue.
Aug 19, 2008 | Samsung ML 1510 Laser Printer
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp photosmart 7960
For Photosmart 7960...
Hit MENU
Select "TOOLS" by hitting OK
Select "Clean Cartridges" by hitting OK
Carefully review printed output for white lines on printed areas
If white lines appear:
Select "SECOND level cleaning" by hitting OK
Select "THIRD level cleaning" by hitting OK.
Jan 17, 2008 | HP PhotoSmart 7960 InkJet Printer
HP Photosmart 6520 e-All-in-One Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
